I can fill machine from diagnostic mode. hot and cold solonoids work ok. will not spin or drain at all. it will agitate,
SOURCE: Fisher Paykel Wash Machine GWL11US
You may have to disassemble the pump from the line and the diverter valve and physically look to see what is happening.
It seems like you have a stuck valve or plugged one.
hot drain pump? suggests that the pump is not being lubricated properly...
SOURCE: washer will not drain water or go into rinse and spin cycle
First thin I would try is to check your thermal fuse for continuity.
Its located on the tunnel that incases the heasting element.
Try putting the machine into diagnostic mode. If it won't enter
diagnostic mode, then you need to replace the main control board.
You also want to check the drain hose, the end of the hose is tapperd
and tends to collect lint. Run a coat hanger up the hose and see if you
can fish something out also check that belt.
SOURCE: Fisher Paykel GWL10US Washer won't spin
It looks like it has to be the control module.
You need to replace it .
It will cost you around $200 .
SOURCE: Fisher Paykel GWL10 US spin cycle issue
check out another website. ths.gardenweb.com/forum/laundry for other fix it tips on FPaykel.
