I purchased a used ROCKFORD FOSGATE X7a Amplifier. It did not come with the remote base control knob. The connection on the amp itself looks exactly like a RJ-45 input. I see RF has a stand alone remote control bass knob, but on the package it says compatible with 2007 RF amps. It has the same RJ 45 connection as the rf x-7 amp, do you think it would work with the RF X-7 amp? The amp was made in 2002.
In most of Rockford's amps, the low voltage detection is connected to the remote input. If the remote voltage is too low and they use the same circuit on this amp, it could trigger the protection circuit.
Disconnect the head unit's remote from the amp. Use a fuse holder with a 3 amp fuse to jump between the B+ connection and the remote terminal of the amp. If the amp powers up, the head unit's remote output may be defective. If it blows the fuse, the remote input or part of the power supply is damaged. Do not try it with an unfused jumper.
