20 Most Recent Rockford Fosgate Punch P550.2 2-Channel Amp - 300W Punch Series 550W Bridged Mono Remote Punch Bas... Car Audio Amplifier Questions & Answers
well id say you have cooked your amp and or subs they can only take beatings for so long. show it no mercy it gives it back,does amp smell do subs smell borrow amp see if subs are ok if so it will be your amp.new one .keep the gain down??
Rockford Fosgate... | Answered on Dec 18, 2014
how many subs are you running on this amp, and how many ohms are they. if the are bridged, try hooking up stereo and see if the problem still occurs. make sure your scrape off all the paint where the amp is grounded to the frame which should be less than a few feet. i'd also recommend running at least a 4ga wire for both your power and ground.
Rockford Fosgate... | Answered on Jan 31, 2011
Short inside one of the transistors. This requires very good soldring skills and electrical know-how, and some thermal paste to go between the heat-sink and the transistor. Unfortunatly this is not a cheap repair, probably cost around 100 dollars.
Cheers,
Kevin
Rockford Fosgate... | Answered on Feb 09, 2010
well, hopefully the amplifier was wired correctly. But either way there are so many factors that can cause this problem... But the biggest one is the amplifier must have been sending some distortion to your subwoofers which a subwoofer can take a certain level of distortion and be fine but too much will blow any subwoofer even the highest of high end subs at a high volume... when your subs hit the point of blowing they will tend to just blow out one at a time... they don't just pop both right away. I'd say get the sub that isn't blown off off of the amp before it blows too... distortion is clipping most of the time... when you destroy the subs it will eventually work it's way to the next component in the system which is your amp and then you will be out an amplifier and subs. save yourself the headache.......
Rockford Fosgate... | Answered on Dec 13, 2009
the ground might be touching
Rockford Fosgate... | Answered on Oct 28, 2009
The amp is blown and need to be repaired.
You can contact Rockford direct to find a repair dealer.
Rockford Fosgate... | Answered on Jul 09, 2009
First off will the fastener turn ? If not try using a bit of wd-40 and letting it "soak" for a little while . Also be sure you are using a good proper sized Phillips screwdriver . If the fastener still won't turn try using a can of "computer duster " inverted so the liquid comes out , note this will be well below zero degrees , and freeze the screw head , then try turning . If the fastener is stripped and the ttol slips you will have to remove the amp cover and grip it with a pair of vise grips ,pliers or a flat blade screw driver .
Rockford Fosgate... | Answered on Sep 24, 2019
You are driving it too hard. If continued, the amp will go into protect mode to save you from yourself.
Rockford Fosgate... | Answered on Jun 12, 2019
Yes. Wire the two 2 Ohm speakers in series and connect them to one channel. Connect the 4 Ohm speaker into the other channel. This will give you a balanced 4 Ohm load on each channel.
Rockford Fosgate... | Answered on May 12, 2019
i have a punch 45 but i'm missing the speaker wire connector.... were do i go to get one...
Rockford Fosgate... | Answered on Feb 03, 2019
Please be more specific. RF doesn’t share schematics
IF you are looking for a schematic diagram on the amp, you wont find it. IF you need the connection information you can look on their site, There is a repair video on that unit attached . Rockford Fosgate Car Stereo Amp Repair
Rockford Fosgate... | Answered on Jan 13, 2019
Car Audio & Video Logo
Popular Tags
7 questions posted
Top Rockford Fosgate Car Audio & Video Experts
seankane89
Level 1 Expert
Professor_V
Professor_V
Robert Rankin
Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Rockford Fosgate Car Audio & Video
Most Popular Question
rockford punch 550 2 amp wont play
  • Car Audio & Video
