690/f freezer compressor runs with unit turned off bad relay
SOURCE: Compressor area above refrigerator is getting very hot
Check Thermostat.
Proper Cleaning/Defrosting of fridge and freezer.
Proper Placing and Distance from wall.
If your hand bear the body temperature of that specific area then its normal.
Contact technician to verify Freon pressure.
Best of Luck,
Regards:
Hassan
SOURCE: compressor keeps running. Hasn't shut off in last
Good chance your FREON or refrigerant has developed a leak. To save money, put your unit in the back of your truck or trailer and take it to a REFER shop and have the Sealed System Checked. They will tell you if it can be recharged or if you Compressor has died. If the compressor has died, generally it means the unit is too expensive to fix. Reason, the cost is high, the recapture of the GAS before it is recharged in expensive, the compressor is expensive, and the recharging is expensive and then putting a new compressor in a older refer could put a lot of pressure on a group of existing old parts... well then, the weakest link will generally break... Not always, but if one does, then your into a older refere and stuck with pouring more money into older unit.. Sorta like pouring money into a hole in the water... They call that a boat... Hummmmm Good luck....
SOURCE: ge side by side not cooling
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong.
If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
hghj
SOURCE: Sub-Zero Model 690 S Refrigerator
The following blog may be of help to you, and suggests that thermisters may be the problem:
http://www.applianceblog.com/mainforums/refrigerators-freezers/3937-sub-zero-model-690-refrigerator.html
This makes sense, especially since it's your last error code.
If the unit has a damper, it could be frozen or stuck, but that's the only other thing I can think of to check.
Good luck, and hope this helps.
SOURCE: my 10yr old model#690 freezer is having trouble
The noise that you are hearing is in the compressor. The motor has rubber mounts that hold the motor inside the compressor. One of these mounts are broke and what you are hearing is the motor hitting against the inside of the compressor. Have you tried cleaning the coils? let me know.
