AVH-Z5050TV pioneer
SOURCE: how to instal my pioneer avh-p57000dvd
you have to run a toggle switch to do it connect the part where it runs from the dvd player to the main connector on the toggle then find a ground and connect that to the ground on the toggle and flip the switch put a dvd in and should work
SOURCE: pioneer AVH-P5700 instalation
You can find a wiring diagram for your 87 monte at http://www.modifiedlife.com/1987-chevrolet-monte-carlo-car-audio-wiring-schematic/ You can refer to the installation manual for your deck at http://akamaipix.crutchfield.com/Manuals/130/130AVHP570.PDF Since you are removing a shaft style radio and installing a DIN style you will need to perform extensive modifications to your dash. The Pioneer manual provides the dimensions.
SOURCE: i have a avh p5700dvd and when i put a cd in it reads error 02
http://www.pioneerelectronics.com/pio/pe/images/portal/cit_11221/212667155AVHP5700DVDOperationManual.pdf
SOURCE: install a pioneer AVH-P6800DVD
Here is a link to the manuals for this device:
http://www.pioneer.co.uk/uk/support/manuals/AVH-P6800DVD/index.html
1st manual is the installation manual, it is mislabled.
Cheers!
