How can i bypass the error on the Pioneer AVH-P4000DVD Monitor with out doing the switch because it looks getto.
Get a relay (4 or 5 pin) from Autozone, O-Reilly, PEP Boys, etc....
Connect wires as follows on relay:
Pin #86 - Amp remote from your radio (blue wire)
Pin #30 and #85 - to a chassis ground (metal dash bracket)
Pin #87 - to Parking brake input wire on your radio (light green)
Pin # 87a - IGNORE. It isn't used in this case.
What this will do is.....
Radio will power on when you turn your key. The amp wire is delayed slightly and will trigger the relay in a second or two. This tricks the radio into thinking your e-brake has been engaged and violla....Mine has worked everyday since I connected it.
