20 Most Recent Pioneer PD-F1007 301-Disc CD Changer Questions & Answers
3answers
Pioneer 301 cd player
I found a fix in another thread. I tried it last night, and it worked. Nothing was broken; a moving plastic piece had just jumped out of its track. Here's the fix:
1. Remove the cover (2 screws on each side & 3 in the back).
2. Find a small white arm (more or less cylindrical, about 1" diameter, & about 3/4" long) and a longer (4-5"?) thin black arm in the center of the unit. These parts load/unload CDs to/from the playing area. You should see that a little knob on the white piece has jumped out of its track in the black piece.
3. Carefully put the knob on the white piece back in its track in the black piece. That should do it.
1/6/2021 6:36:11 AM • Pioneer PD-F1007... • Answered on Jan 06, 2021
No Disc Light
HI, the Optical lens assembly has failed. either the attached motor has failed or, the lens has burned out.
this assembly will need to be replaced as a whole by the manufacturer in this case. the replacement parts are not available for consumer purchase.
Contact pioneer for a repair ticket asap.
8/22/2018 11:37:36 PM • Pioneer PD-F1007... • Answered on Aug 22, 2018
0answers
A homemade CD got caught in the turntable and now
Try this:1. Remove the cover (2 screws on each side & 3 in the back).2. Find a small white arm (more or less cylindrical, about 1" diameter, & about 3/4" long) and a longer (4-5"?) thin black arm in the center of the unit. These parts load/unload CDs to/from the playing area. You should see that a little knob on the white piece has jumped out of its track in the black piece.3. Carefully put the knob on the white piece back in its track in the black piece. That should do it.
12/13/2011 8:32:27 PM • Pioneer PD-F1007... • Answered on Dec 13, 2011
The turntable is jammed does
12/13/2011 8:32:01 PM • Pioneer PD-F1007... • Answered on Dec 13, 2011
Hello, where can I get
You can download on
http://www.pioneerelectronics.com/pio/pe/vgn/images/portal/cit_11221/49439PRB1300A_200012292224475600.pdf
are the same commands
Rate my answer an give points.
Is important for people who share their knowledge, know your comments.
If the answer is helpful, rate my answers
9/20/2011 1:19:46 AM • Pioneer PD-F1007... • Answered on Sep 20, 2011
Looking for the manual.
Register and download the manual for free audio.manualsonline.com http://audio.manualsonline.com/manuals/mfg/pioneer/pioneer_pd_pdf1007.html The service manual... http://www.kallhovde.com/pioneer/tricomp/Audio/PD/PD-F1007_RRV2001.pdf Now, what
4/26/2011 6:41:13 PM • Pioneer PD-F1007... • Answered on Apr 26, 2011
When i push power player clicks rapidly then shuts
Problem with the power relay. The only option is - get in touch with a electronic technician who will better diagnose the parts and replace them.
3/5/2011 3:37:48 PM • Pioneer PD-F1007... • Answered on Mar 05, 2011
Error code UI when I
hit the thingymajiggermabob inside of it with a hammer than it shall work if not get a new one problem solved
12/20/2010 8:10:44 AM • Pioneer PD-F1007... • Answered on Dec 20, 2010
Hi my my display does not work, none of the
12/20/2010 7:14:43 AM • Pioneer PD-F1007... • Answered on Dec 20, 2010
I need Pioneer PD-F1007 301-Disc CD Changer manual
http://www.pioneer.eu/eur/support/manuals/PD-F1007/index.html
10/24/2010 5:19:23 AM • Pioneer PD-F1007... • Answered on Oct 24, 2010
My Pioneer PD - F1007
if you email me [email protected] (put pioneer pdf in title) will sed you service manual with realignment instructions plus disassembley instructions regards yammandan
8/19/2010 6:20:07 PM • Pioneer PD-F1007... • Answered on Aug 19, 2010
I've owned an Antique Apparatus CD-91 counter
Hi Nick,
If you still have this problem I would contact Bruce Wentworth in the USA, listed below are his details.
Regards
Alan Hood
ami-man
UK
Bruce Wentworth A&B Jukebox Repair 56 Old County Rd. Plaistow NH 03865. A&B Jukebox Repair specializes in the repair of Rowe circuit boards in Rowe ...
www.abjukeboxrepair.com/
3/26/2010 11:59:10 AM • Pioneer PD-F1007... • Answered on Mar 26, 2010
Player displays -UI-
According to the manual: U1= "The disc may not be loaded properly in the rack." Countermeasures: Reload disc Check for foreign object on disc Check for foreign object on rack
8/11/2009 6:07:25 PM • Pioneer PD-F1007... • Answered on Aug 11, 2009
Getting 'no disc'
HI.This will occur when the optical assembly becomes unstable. this ((Whole One Piece)), assembly incorporates the spin/load motor, optics housing /arm, tracking device and tracking rail. This is connected to the loading dock assembly. This 'NO Disc', code is the result of a failed or burned out lens. It is possible that you have a dirty lens cap. you can try using a cleaning disk in this case to confirm actual lens failure. if the cleaning doesn't restore normal reading capabilities, this will confirm my diagnosis.
You will need to have the optical assembly replaced in this case. once replaced, your unit will be able to read and track once more.
7/26/2009 6:48:06 PM • Pioneer PD-F1007... • Answered on Jul 26, 2009
Pioneer PD-F1007 301-Disc CD Changer Logo
29 questions posted
Top Pioneer Car Audio & Video Experts
 Francisco Mauricio...
xxxxxx xxx
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Pioneer Car Audio & Video
Most Popular Question
looking manual
  • Car Audio & Video
