SOURCE: crosley cr 78 cd record player plays to fast.
move the needle arm to the extreme right and the turntable will start spinning, this is the problem with the younger generation.....no skills!!!
SOURCE: Whenever i press play, my MP3 player doesn;t play ANY song!!!!
I had the same problem, and I was ready to take the player back. I was searching under media help and found the help I needed. This is what you need to do: open your media player. Along the top it will read Now playing, Library, Rip, Burn and then SYNC. Sync is what you need to click on. In the area that you would drag music to for a playlist will now have ' Connect A Device'. The rest should be easy to follow. Good Luck!
SOURCE: My dvd player dvp615 doesn´t play dvd discs. only music cd´s
The unit has two lasers one for the cd and one for the dvd, the one for the dvd is bad and the whole laser assembly needs replaced. Cheaper to buy a new player.... sorry
SOURCE: I have a Crosley CR248 cd record player/recorder stopped working
If nothing lights up and the whole unit is dead, you may have a blown fuse, a bad power supply, or an electrical outlet that is not giving you power. (Don't laugh, it has happened to all of us... the "broken" thing wasn't plugged in or the outlet it was plugged into was off for some reason). Anyway, if the thing lights up and everything else in the system works except the turntable going 'round, perhaps there is a slipped or broken belt. Most late-model Crosley turntables have been belt drive, so the first thing to look at if everything else works is to press the buttons to start the record playing and then turn the record gently around with your finger on the label, making the whole platter turn clockwise when looking down at the record. Mechanically, the tonearm should cue up and pivot in to the record and it should gently drop onto the record. If you cue the tonearm up and move it in to the end of the last song on the LP and let it back down and turn the record again, it should follow the record's grooves into the center of the record and then lift and "park" the tonearm after everything is done. During the time the needle is on the record and you are turning the record, you should hear the record playing (it will sound bad, because you won't be turning at the right speed!), but that should indicate that the turntable is working mechanically and electrically.
If everything works like I mentioned except the record player won't make the record turn, the next step is to see why it isn't turning. you'll need to lift the plastic platter off the turntable. Most of these have a snap ring (usually a simple spring wire ring that doesn't go all the way around the center spindle. It may have an E-ring instead. Use a small screwdriver to pop this off and be sure to catch it, it might try to pop off the turntable and fly across the room! Lift the platter and you'll probably find a broken belt underneath. You'll have to replace that to make the records spin again. The hardest part is to locate a replacement belt! If nobody near you stocks belts (lol) then online outfits like LPGear.com can be a source. After you replace the belt and put the platter back on the player, remember to replace the snap ring. You might want to lubricate the platter's bearing with an appropriate lubricant, but that is your call as to whether that will be necessary. This is likely a styrene or simple thermoplastic plastic bearing, so be real careful what you use for a lubricant! if you're not sure, don't use anything! Like I said, it's not a difficult repair, it's just hard to find the part these days! Good Luck!
