Question about Crosley Audio Players & Recorders
My Crosley turntable is spinning too fast at 33RPM
My Crosley record player is spinning too fast at the 33RPM setting. What can I do?
Posted by agrantfisher on
Anonymous
    Scholar:
  • 84 Answers
Mismatch speeds on older turntables is normally due to either 1) a kink in the speed switch mechanism or 2) a hardening and slipping of the rubber drive wheel.
A very small motor with a chamfered shaft drives the rubber drive wheel, and the wheel is moved by the speed control up and down the drive shaft to produce various rpm speeds.
In your case, it's likely turning at 45rpm because it isn't settling onto the 33rpm part of the shaft.
Piddle with the speed control, then count the speed (number of turns in a minute) You'll figure it out!
Posted on Nov 25, 2009
  • miquel enrigue Jan 06, 2013
    if it isn't settling on 33rpm how can i fix it?
  • Ross Kelly
    Ross Kelly Jul 13, 2014
    One youhave unplugged the unit, you need to get access to the guts of the thing. They come in various styles, and with mine you ignore any screws on the base! Access was gained by separating the player deck from the wooden base and sides. If you have accomplished this feat, you need to find some little "trim pots" near the motor. On mine there were three screws close together that tweaked the speed. They are very sensitive. Firstly try the one on the right, and turn the screw a fraction clockwise. Now get out a stopwatch and time the revolutions per minute - obviously you want it to go round 33 times each 60 seconds. It may take you quite a bit of fiddling, but it can be done. Again, be VERY careful to unplug the unit each time you tweak the screws. If you are not sensible enough to attempt this, take it to a shop.
John Cipollina
    New Friend:
I have the Crosley89 stackomatic.
the 33.3 rpm was more like 35.5rpm. Sounded awful .
I took off the bottom panel, found the motor,
put small jewelers slot screwdriver DEEP into hole marked
"L" ( I guess for Long playing)
and when I made contact I turned counterclockwise just a drop.
When I checked it went down to 33.6rpm
so I left it. Sounds good to me and I didn't have to throw out the machine. Hope this helps.
Posted on May 01, 2018
Crosley troubadour stops before record is done
Check to see if there is a switch setting for 7", 10", and 12" records. Sounds like a switch setting to me. Does it always pick up at the same physical location on any record? If so, that is the likely cause. Personally, if you have an extensive collection of vinyl, a Crosley is definitely NOT the best turntable to be playing them on. You'd get way better fidelity and save your records from physical groove damage by investing in a better turntable. If you want the collection to stay in good shape and retain their value, ditch the Crosley ASAP.
Dec 03, 2017 | Crosley Audio Players & Recorders
MY TURNTABLE START PLAYING ON THE SECOND SONG OF THE 33" VINYL, WHAT IS THE PROBLEM
Do you have a switch to select the size of the record as well? We had a record player that could play 7" singles at 33rpm (floppy vinyls given away by Sunday papers). We had to select 33rpm and also 7" on a separate lever for this to work.
May 23, 2014 | Marantz Audio Players & Recorders
Crosley CR40 playing 33 1/2 too fast? What can I do to slow it just a little bit?
I would get a vintage turntable and not a new one inexpensive one. The new record players do not last.
Apr 20, 2014 | Crosley Stack-O-Matic CR40 Turntable
My turn table is going to fast when i play an record , what can i do to fix this? thanks
Hello the turn table has two speeds. 45rpm and 33rpm (rotations per minute) If you are playing a record that takes up the entire turntable you need to set it on 33rpm. For the records that only take up half of the turntable you want to set it on 45rpm. Setting the turntable on the wrong setting for a certain size record can make the record play to fast of to slow.
Mar 24, 2011 | Panasonic Technics SL-BD22D Turntable
Crosley Record Player Stopped Spinning...
I had this same problem with my Crosley 704 and it bamboozled me to no end.
After digging around I dug up the manual online (I bought mine used so I didn't have one to consult). It turns out the record stops when it gets to the end, and to get it spinning again you have to lift up the tone arm and move it right (past the holding latch) until it clicks, and voila, it starts spinning again, ready for a new record.
You'd think that they coulda made it more obvious :(
Jan 12, 2010 | Crosley Audio Players & Recorders
Crosley cr 78 cd record player plays to fast.
move the needle arm to the extreme right and the turntable will start spinning, this is the problem with the younger generation.....no skills!!!
Dec 12, 2008 | Crosley Conductor CR73 Turntable
Sony ps-lx250h belt-driven turntable runs too fast.
Is there an adjustment knob? if so use that! if not it will have to be adjusted from under the turntable!
this should fix ya!
Dec 12, 2008 | Sony PS-LX250 Turntable
6,344 people viewed this question
Top Crosley Audio Players & Recorders Experts
 Grubhead
Grubhead
efs_perpends
efs_perpends
Are you a Crosley Audio Player and Recorder Expert? Answer questions, earn points and help others
