20 Most Recent Crosley Stack-O-Matic CR40 Turntable Questions & Answers
I would get a vintage turntable and not a new one inexpensive one. The new record players do not last.
Crosley... | Answered on Oct 15, 2016
If the voice coil to the speaker is damaged, you have to replace it with an other one.
Crosley... | Answered on Jul 24, 2014
I don't think it's likely that the motor is in trouble just by having the belt wrong. It would require more physical damage to cause the motor to play up. Having said that the motor could have been in trouble before you touched the belt. But you do need a new belt, all you need to do is measure the diameter of the belt in mm. You might also need to measure the width. To find a new belt put the words "turntable drive belt XXmm" into Google. You can add Crosley to the start, but many belts are universal. Your measurements don't need to be spot on with the diameter, so if you have measured it at say 95mm, a 90mm to 100mm belt will do the job. However fitting the new belt is a different matter. You need to know the correct way, or the speed might be wrong. I can't help you with the fitting of it, so you will need to check how to do it. Some makes have YouTube videos of the fitting. I would just look for Crosley and see if any look like your model.
If fitted correctly and there's a problem with speed still, then you should look more closely at the motor.
Crosley... | Answered on Mar 26, 2014
Check to see if the belt that drives the turntable is slack or off.
Crosley... | Answered on Aug 20, 2013
Check all the cables and connections IE to the cartridge. If the problem continues contact the dealer who sold it you.
Crosley... | Answered on Dec 23, 2012
It could be the adapter is just faulty, but you can't tell to you get power to the unit if any part has failed inside (most liklely the transformer if it has).
I found this step-down adapter on amazon which should do the trick, not expensive either.
http://www.amazon.co.uk/Stepdown-240-120V-Transformer-45VA/dp/B000NJ26X2/ref=pd_cp_ce_1
Crosley... | Answered on May 31, 2012
It sounds like you have too much pressure on the tone arm. Check the underside for springs. You might be able to remedy the problem the old fashioned way. Tape a coin onto the top of the tone arm, as far to the rear as possible. This will eliminate some of the downward pressure onto the record.
Crosley... | Answered on May 07, 2011
Contact the shop you got it from, it might have got damaged in transit.
Crosley... | Answered on Feb 02, 2010
Hello Tom, you would have to measure if the engine gets power, also control the key that drives the engine when it starts
Check if you can move the motor shaft with your hand, to confirm that it is not locked
Good luck with the checks
Greetings Franco Dosil
Hola Tom, tendrias que medir si le llega alimentacion al motor, tambien controlar la llave que acciona al motor cuando arranca
Fijate si puedes mover el eje del motor con la mano, para corroborar que no esta trabado
Suerte con los chequeos
Saludos Franco Dosil
Crosley Audio... | Answered on Apr 19, 2019
Crosley Stack-O-Matic CR40 Turntable Logo
14 questions posted
Top Crosley Audio Players & Recorders Experts
 Grubhead
Grubhead
efs_perpends
efs_perpends
Are you a Crosley Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Crosley Audio Players & Recorders
Most Popular Question
turntable stopped working possible belt
  • Audio Players & Recorders
