Question about Crosley Audio Players & Recorders
Cd will load but not play
It is a crosley cr44cd collectable edition my cd player does not register my cd on the front and will not play
Posted by Sharon Nelson on
Aron
    Top Expert:
  • 2,492 Answers
The CD could be scratched or there or there is a problem with the laser and it needs a new laser.
Posted on Feb 17, 2023
Crosley troubadour stops before record is done
Check to see if there is a switch setting for 7", 10", and 12" records. Sounds like a switch setting to me. Does it always pick up at the same physical location on any record? If so, that is the likely cause. Personally, if you have an extensive collection of vinyl, a Crosley is definitely NOT the best turntable to be playing them on. You'd get way better fidelity and save your records from physical groove damage by investing in a better turntable. If you want the collection to stay in good shape and retain their value, ditch the Crosley ASAP.
I just purchaseday crosley model #2405c and when you put a cd in and push play button it does not work
Hi
You can find a manual here
http://imgserve.crosleyradio.com/manuals/CR2405C%20manual%20%20%20English_French_Spanish%202011.12.19.pdf
which may or may not help with your problem.
However you state that you have "just purchased" the machine. If this is so and particularly if the machine is new then you should take it back to the vendor for him to replace with a working unit, because clearly the one you have is "not of Merchantable Quality".
Hope this is helpful, if so would you please register that with Fixya
Cheers
Cd recorder
follow this test and fix it. God bless you
Does not play disc
  1. No disc. - Load a disc into the tray.
  2. Disc has been loaded upside down. Place the disc with the label side up.
  3. Disc region code does not match region code of the player.
  4. Disc type is not the correct type to play.
  5. Disc is damaged or dirty. Clean the disc or try another.
  6. Moisture may be condensed inside the unit. Remove the disc and the leave the power on for one or two hours.
Got a thin line on the tv screen when tv is on
a thin line across the tv screen is called horizontal collapse it is caused by a power fault in some cases its simply a blown capacitor. in other cases it can be from the main transformer. in most cases the repair is more expensive than the unit to replace but it depends on the unit and your value to it. in any case it needs to be repaired by a good tech. make sure you get a quote up front so you know what your looking at paying.
best of luck to you.
2answers
Crosley songwriter cd recording problem
maby the formatt its wrinting on is ther any options in menu of it to set the output formatt to mp3
Top Crosley Audio Players & Recorders Experts
 Grubhead
Grubhead
Morne Olivier
Morne Olivier
Are you a Crosley Audio Player and Recorder Expert? Answer questions, earn points and help others
