20 Most Recent Crosley Songwriter CR248 Shelf System Questions & Answers
Hi Jaime , usually it refers to the cost to repair is far more expensive than you buying a new unit. This is common with the newer equipment made in China.
Crosley... | Answered on Jun 03, 2014
It is cooked.
Crosley... | Answered on May 21, 2014
Hello Tom, you would have to measure if the engine gets power, also control the key that drives the engine when it starts
Check if you can move the motor shaft with your hand, to confirm that it is not locked
Good luck with the checks
Greetings Franco Dosil
Hola Tom, tendrias que medir si le llega alimentacion al motor, tambien controlar la llave que acciona al motor cuando arranca
Fijate si puedes mover el eje del motor con la mano, para corroborar que no esta trabado
Suerte con los chequeos
Saludos Franco Dosil
Crosley Audio... | Answered on Apr 19, 2019
There is no locking mechanism...you may have to pry it, but you are on your own! This is totally up to you as there could be any number of reasons why it is stuck...No responsibility on my end...
Crosley Audio... | Answered on Dec 04, 2018
Plug in your USB or SD card, select the correct input and you are good to go...
I am wondering if you were ever successful in getting any sound? My unit is doing the same thing, but it has been since I plugged my phone in the line-in jack. Everything is powered, but no sound and I called Crosley and it is a discontinued model. There is no phono/line switch and if there was, I believe my problem would be solved. Thank you, if you get this and answer what your results were!
Crosley Songwriter CR248 Shelf System Logo
3 questions posted
Top Crosley Audio Players & Recorders Experts
 Grubhead
Grubhead
efs_perpends
efs_perpends
Are you a Crosley Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Crosley Audio Players & Recorders
Most Popular Question
no sound coming out all
  • Audio Players & Recorders
