20 Most Recent Crosley CR49-TW Tweed Traveler Turntable CD Player Questions & Answers
plaese change the power cable and check the main fuse
Crosley CR49-TW... | Answered on Oct 01, 2017
Make sure the switch on the back for line in, is off! I had mine on and it would not play. Switched it off and all works fine!
Crosley CR49-TW... | Answered on Jan 17, 2017
These Chinese made plastic products are not the real thing. It can be fixed but will not operate long term like a real stereo system. For a reliable product you need to be using Technics type turntables and Samsui or Pioneer receivers to get a real system working. They are big and heavy and that is why a lot of them are still working after 40 years.
I know because I have some of those products here- they can be repaired to last as well. I do the repairs.
Crosley CR49-TW... | Answered on Jan 25, 2013
Don,t try, You will just damage it, Take it in for repair,Where they no what there doing. If you damage it then it will be verry costly to have it repaired,
Crosley CR49-TW... | Answered on Nov 09, 2012
1) Remove the platter - just lift up
2) Underneath the platter, you'll see a small lip section
3) Wrap the belt around this lip
4) Put platter back on turntable
5) Rotate platter until you see the motor shaft through the holes on the platter - a brass round looking piece
6) Pinch the belt around the motor shaft.
7) That's it.
- OPTiC
MasterTech
Digital Analog Therapy
Turntable Parts : Turntable Repairs
Crosley CR49-TW... | Answered on May 12, 2012
Lift platter and refit belt. [email protected]
Crosley CR49-TW... | Answered on Sep 15, 2010
Sounds to me like your belt is streched. Under the felt of the turning section, there should be two rather large holes. Insert your thumb and forefinger and pull the table off. You should also see where the existing belt is running. Insert new belt around the motor first and replace the table section. Now, through the two holes, manouver the belt onto the table section until it spins freely
Crosley CR49-TW... | Answered on Jun 12, 2010
Crosley CR49-TW Tweed Traveler Turntable CD Player Logo
Popular Tags
34 questions posted
Top Crosley Audio Players & Recorders Experts
 Grubhead
Grubhead
efs_perpends
efs_perpends
Are you a Crosley Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Crosley Audio Players & Recorders
Most Popular Question
record player turn
  • Audio Players & Recorders
