SOURCE: ds lite suddenly stopped working
The orange light goes off when the battery has been charged to its highest capacity. After every charge, the batteries capacity is decreased. Get a new battery, that should do it.
SOURCE: HP md5020n does not have picture
UNPLUG IT AND IFF YOU CAN TAKE THE BACK OFF ,,AND CAREFULLY LOOK ALL IN THERE FOR A FUSE ,,SEE IF ITS BLOWN,,
SOURCE: My Yp-p2 does not turn on. When I try, it blinks red.
it locked just slide the hold swith above the pwer button *facepalm*
SOURCE: My Kyocera Zio won't turn
I had the same problem but I held the power button for about 30 seconds or until it stopped blinking then I hit the power button again shortly after then it worked. I hope this solves your problem also.
SOURCE: my sony kdf e50 12u wont turn on red light blinks twice
Your TV is giving you a code, something is faulty in the system, usually 2 blinks of the red light indicates, Load on power line is shorted. I also would check the bulb also to make sure it doesn't need replacing.
