Question about Kyocera Cell Phones
How do you hard reset a kyocera c6745 - Kyocera Cell Phones
Posted by Bob Smith on
  • emile donis
    emile donis Apr 16, 2016
    I have a kyocera c6745 how can i do a hard reset
richie46
    Top Expert:
  • Kyocera Master
  • 12,962 Answers
Try removing the battery on phone while it is still turned on.
Then press and hold the power button for at least 30 seconds. Reinstall the battery and press the on button and see what happens.
Posted on Mar 10, 2016
  • Saint Charles Dawinson
    Saint Charles Dawinson Feb 04, 2018
    IT IS NOT EASY TO REMOVE THE BATTERY ON THE KYOCERA PHONE
    there's no other way to help?
Kyocera c6745 hard reset
1. Back up all your data.(or not)
2. Turn off the phone.
3. Press and hold the "Volume Down" and "Power key" at the same time.
4. When the phone vibrates, release the "Power key" ONLY.
5. When the Android recovery screen appears, release the "Volume down key".
6. Press the "Volume down key" until "wipe data/factory reset" is selected, then press the "Power key".
7. Press the "Volume down key" until "Yes - erase all user data" is selected, then press the "Power key".
8. Press the "Volume down key" until "reboot system" now is selected, then press the "Power key".
9. They phone should now shut off and restart.
Dec 12, 2017 | Kyocera Cell Phones
What are codes to unlock a kyocera phone model:C6745
I suggest you can approach Superunlockcodes.com and specify the country,locked network of Kyocera C6745.Based on the availability you can get the permanent unlock service along with free instructions.
Nov 16, 2017 | Kyocera Cell Phones
Kyocera model number c6745 how to reset
Hold down the Power key in order to switch off the cell phone.
In this step press and hold the Volume Down
+ Power button for a few seconds.
You should release held keys when the
Recovery Mode starts.
Afterwards press Volume Down a few timies
to highlight "wipe data/factory reset ", and
then push the Power button to confirm this
option.
Next, select "Yes--delete all user data ". Use
Volume buttons to scroll and Power rocker to
select.
6. When the Recovery Menu appears
on the screen, choose "reboot system now ".
Oct 11, 2016 | Kyocera Cell Phones
If I use 00000000 to reset PUK code what do I make the newnone it's a Kyocera c6745 thanks.
PUK codes are only available for your service provider
call them on another phone , provide proof that you own the account and they will give it to you
a lot easier than what you are doing and here is the thing--if you write down the code , you can use it as often as you like on that phone if you mess the PIN number
Jul 10, 2016 | Kyocera Cell Phones
I can't take the batteryR out of my Kyocera c6745 hydro air. The phone keeps turning off and on by itself till the battery finally dies. It won't go past the kyocera screen
The battery comes out. They got it in, didn't they? If still having hassles go to a phone place and have them remove and replace the battery.
Jun 13, 2016 | Kyocera Cell Phones
How do i get out of a bootloop on a kyocera c6745
http://kyoceraphonereview.blogspot.com.au/2014/08/how-to-fix-kyocera-boot-loop.html This is a link to the procedure, it shows a samsung but the method is the same, if it still won't work, press the power button several times before putting the battery back in.
May 13, 2016 | Kyocera Cell Phones
C6745. How can I hard reset?
Hi Emile. The link below is a short youtube video on how to rest the pattern code on your phone, The
guy shows 3 way but the 3rd way is a factory reset meaning you loose every thing in your phone
but the first two ways are worth watching. I hope this helps...... CHEERS..https://www.youtube.com/watch?v=dmBqvh1UUD4
EASY WAYS How To Unlock Android Passwords
Apr 16, 2016 | Kyocera Cell Phones
Cell Phones Logo
Top Kyocera Cell Phones Experts
efs_perpends
efs_perpends
Harrie
Are you a Kyocera Cell Phone Expert? Answer questions, earn points and help others
