Question about Kyocera Cell Phones
How to download files to a computer from a Kyocera S2100
Posted by Carl Jagger on
  • Carl Jagger Apr 21, 2011
    My cell is a kyocera S2100 I can not find a driver and I have both Vista and Linux both which do not reconize the pluged into USB port cell.
  • George McShire Mar 08, 2013
    sorry I have one and no its not made for data transfer with a computer. sad that my old PDA could but not my cell phone.
Lebanon Raingam
  • 4,737 Answers
I am not a Kyocera expert, but let me share what I know about it. When you connect the phone to the computer via the usb cable, did something pop up on your computer screen like asking for driver or etc? In most Kyocera phones, there is a settings called "Mode Settings" which is a sub-settings of "Settings", Open menu and check whether you can find "Mode Settings" under "Settings" or not. If so, open it and select "Mass Storage Mode". Once this is done and the changes is saved, connect the phone to your computer Via usb cable. You should see a new "Removable Disk" in the "My Computer" explorer. That new "Removable Disk" (in windows) should be your Kyocera's memory/memory card. Open it and check the contents. To do this, you don't need driver or software since almost all Microsoft Operating System came with the usb driver for mass storages.
Let me know if you need further help.
Good Luck
Thanks for using FixYa.
Posted on Apr 21, 2011
  • Patti Bell
    Patti Bell Jan 25, 2015
    Lebanon, I have a S2100 Kyocera, but do not have a Mode Settings option on my phone...what now?
Anonymous
  • 438 Answers
Jagger,
There are a number of ways to do that.
1. Use the USB cable to connect and set the phone as a mass storage device from settings. It will appear in My Computer as an additional drive. Use this additional drive as you would a normal drive to copy paste files etc to and fro.
2. If the phone has internet activated on it then send these files as email attachments and receive them on the PC.
3. Remove the memory card after copying all the files to it and have the card read by the computer and copy/paste the files to computer.
Anonymous
    Genius:
  • 1,196 Answers
1.Plug one end of the USB adapter into the phone, and the other end into an available USB port of your computer. Look to the bottom right of the screen and you should see an "Installing Driver..." window pop up. Wait a few minutes to allow the computer to look for a driver for your phone
2.Look for a window to pop up that tells you "Driver was successfully installed." If it never comes up, or instead a window pops up that says "Driver was not successfully installed," it means your computer did not recognize your cell phone. In this case, you'll need to look for the driver. If it did install, skip ahead to Step 5.
3.Install the driver by double-clicking on it. Before you do this, make sure your cell phone is unplugged. After you've installed the driver, plug in the cell phone, and it should be recognized
4.Go to "My Computer." Look for a new drive that has either the brand/model of the cell phone in the name, or simply a picture of the cell phone on the drive. It will probably have the drive name F:, I: or G:. Double-click on it.
5.
Go to Start > File > Settings > Folder Options and select to enable hidden files and folders to be shown. Then go back to your cell phone's folder and look around. You should see a folder with the name "Pictures," "Photos," "images" or a similar name. Double-click on it, and you should see all your cell phone files.
6.
Select files you want to download and right-click "Copy." Then go to your desktop and create a new folder by right-clicking and selecting "New Folder." Open up this new folder, right-click and select "Paste." Your files will then be copied from the cell phone to your computer where you'll be able to access them any time.
Posted on Apr 18, 2011
Have 3 0f these phones bought new charger and still will not come on
Hi Stella, I would take all 3 phones and new charger to a cell phone store and get some advice from a store person... I'd say faulty new charger.....CHEERS..
Mar 27, 2016 | Kyocera Clip S2100 Paylo Prepaid Phone...
I need instructions for paring with my phone
Make sure your phone is on discoverable bluetooth on, power on your device, it will be auto on, then your phone may give you a code to punch in or you may just connect. Pretty simple, I found it sometimes asks you to put the code in if you are some distance from your device, ignore it, it should just take a minute and will connect auto.
Apr 21, 2015 | Jabra Cruiser 2 Bluetooth In-Car...
Cannot open downloaded files on Kyocera hydro. It
My kyocera hydro has the same can.t open file,but I dont have a home computer,what do I do.
Oct 11, 2014 | Cell Phones
How do I get my text messages transfered to my laptop so I can print them off? I have a kyocera hudro
. Download BackupTrans Software's "Android SMS + MMS Transfer" software .It help us extracts SMS and MMS messages from any Android device and stores them on the PC.
2. Connect your Kyocera Hydro to your PC via mini USB cable. "Android SMS + MMS Transfer" will scan your drive and create a list that it can sync to your computer.
3. Click on "Kyocera Hydro" under the list of devices in the left-hand panel of the software.
Select the messages from the list, click "File" -"Print SMS and MMS." Select your printer and then click "Print."
App Option
4. Press the "Home" button on the Kyocera Hydro.Tap the "Google Play" icon to open the application market. Search for "PrinterShare Mobile Print." Tap "Install" to download and install the software.
5. Both the printer and the phone need to be on the same wireless network.Tap the app to searches the network for the printer.
6. Tap "Messages" to open your SMS and MMS messages in PrinterShare. Select the wireless printer.
Manual Method
7. Click on the messages and then tap"Copy message text".
8. Return to your Home screen and then open the email app.Compose a new message to yourself and paste the messages you want to print.Tap"Send".
9. Open the email on any computer connected to a printer and then click "File," and choose "Print".
10. Then you have successfully print your message from Kyocera Hydro.
Aug 12, 2014 | Boost Mobile Kyocera Hydro Smartphone
KM-5050 Scanning Issue
the 5050 uses a file scan utility which is basically an ftp utility. you need to download the scanner file utility on each workstation. HERE is the link for the utility and instructions file.
Jul 18, 2013 | Kyocera Office Equipment & Supplies
Fuji s2100 internal memory
The best way would be to use the "Copy" command in the Playback menu to copy the pictures from the internal memory to a memory card, then copy them to your computer by plugging the card into a card reader (either built-in to the computer or connected via USB or FireWire).
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
May 09, 2012 | FUJIFILM Finepix S2100HD Digital Camera
Kyocera s2100 recent calls
All you have to do is press the "down" button.
Apr 22, 2012 | Kyocera Slider Cellular Phone
No installing option
locate the file you downloaded on your computer (hopefully on the desktop so you can find it) double click on the downloaded driver to start the install.
Apr 16, 2009 | Kyocera FS-5025N Laser Printer
Cell Phones Logo
Top Kyocera Cell Phones Experts
efs_perpends
efs_perpends
Harrie
Are you a Kyocera Cell Phone Expert? Answer questions, earn points and help others
