20 Most Recent Kyocera K10 Royale Cellular Phone Questions & Answers
from the website:
How do I set speed dial for one of my contacts? First, find the contact in your Contact List, highlight it, and press OK. Then select Options -> Speed Dialing and press OK.
Choose one of the numbers from the list and select Assign to assign it to your contact. You can now use 1-Touch Dialing for that phone number. Just press and hold that assigned one or two digit number instead of dialing the contact's entire phone number.
Kyocera K10... • Answered on Jul 23, 2010
I appreciate your help - Fixya has assisted me before on another problem. Re phone, found the old manual and resolved problem. thank you
Kyocera K10... • Answered on Jan 18, 2009
first, take out the battery and press the RED end call key for 15 seconds, then put the battery back in and turn on the phone.
if that doesn't work then try this from the website.
How do I lock/unlock the phone's keypad? To lock and unlock your phone's keypad, press and hold the left navigation key.
Or, select Menu -> Settings -> Keyguard. Then highlight either of the options and press the OK button. You can set your phone to lock the keypad immediately, or automatically if no key is pressed after 30 seconds, 1 minute, or 5 minutes.
To unlock the keypad: Press 1-2-3 in that order."
good luck!
Kyocera K10... • Answered on Jan 11, 2009
Kyocera K10 Chronic Problem. It Shuts Off Unintentionally, Automatically.
There is an inherent problem in the K10 cell phone and VirginMobile knows it. They will automatically shut off several times a day at random intervals.
They will send a 'refurbished' replacement free of charge. Most of these are phones customers sent back for the same problem. They give it a quick test and then send it along as a replacement to the next customer.
After the third ( that's right, count 'em, THREE) replacement phones, they finally sent me an Kyocera Oyster phone as a replacement.
I had my original phone 2 years before the problem began. I read somewhere that it is a virus afflicting the K10. Virgin Mobile will not officially acknowledge th problem but their some of thier customer service reps will. Have this problem? Contact VM.
[email protected]
Kyocera K10... • Answered on Dec 15, 2008
How can i remove pin lock from au urbano v02
Kyocera Cell... • Answered on May 05, 2021
I think it has happened due to a software update. I will suggest you do a hard reset and check it. After reset let the phone completely start fresh and I hope the error will not happen again.
Kyocera Cell... • Answered on Dec 12, 2020
If your cell phone is not charging I will suggest you to: First, change the charger cable and check If the above step does not work then, change the charger Moreover, the last possible solution is changing battery.
Hard Reset (Factory Reset) Press and hold the power button to turn off the phone. 2. Hold down the "Volume" "Power" and "Home" buttons at the same time. Continue holding the buttons until the 3-D Android logo and a menu of system options appears on the screen, and then release the buttons.
Kyocera Cell... • Answered on May 19, 2020
Before restoring your Android text messages, you need to know one thing- why these deleted messages are recoverable? It is actually easy to understand if you know how deletion works: When you delete or remove text messages on Android phone, they would be first moved to the trash bin and the device will mark these files as inactive. That is to say, they still exist on your phone but are invisible and replaceable. And the system would not really erase them until you add some new files to cover them. Thus, you should stop using your phone if you wish to get back the deleted SMS or you will permanently lose them. Restoring your lost Android messages to computer would be a safer way since you can backup them to PC at the same time. But to achieve this goal, you need to find a professional yet reliable Android SMS Recovery software as your assistant - MobiKin Doctor for Android (Win/Mac). https://www.mobikin.com/android-recovery/recover-deleted-text-messages-from-android.html
Kyocera Cell... • Answered on Dec 23, 2019
Kyocera K10 Royale Cellular Phone Logo
Popular Tags
16 questions posted
Top Kyocera Cell Phones Experts
efs_perpends
efs_perpends
Harrie
Are you a Kyocera Cell Phone Expert? Answer questions, earn points and help others
View Most Popular
Kyocera Cell Phones
  • Kyocera Cell Phones
Most Popular Question
deleting calls
  • Cell Phones
