20 Most Recent Kyocera Oystr KX9 Cellular Phone Questions & Answers
what did you do
Kyocera Oystr... | Answered on Aug 15, 2016
I hope that when you say blank it means partially lit, with a kind of background, but no image.
This solution is not for an abused phone, as it does not seem to be mechanical, or due to a loose connection. It rather seems like a firmware failure. It will not make your phone usable, instead, it will enable you to retrieve your saved numbers. Once these cheap things start failing they become disposable.
Tried removing battery: No cigar. Tried opening it carefully (under 90 degrees) still no solution.
Here's what worked for me. Phone off, either by powering it down of by having removed the battery.
Get a toothpick, and with the phone CLOSED in the off position, pinch the power-on button and let the phone come on closed. It may not work the very first time, but you should be patient. Once it comes on, you can do just about anything with it until you power it down.
**Make sure you have charged your battery prior to this, since will be spending some time retrieving your numbers**
Good Luck!
Kyocera Oystr... | Answered on May 25, 2013
mymomcallsme solution works, I had the problem, removed battery fer a while, viola! Screen is back. Thanks mymomcallsme
Kyocera Oystr... | Answered on Jan 22, 2013
There is no "button" to dial the voicemail. (you didn't read manual).
You access your voicemail by dialing YOUR OWN CELL NUMBER.
(find it here): Menu / Settings / Phone info / Build info / YOUR #.
(copy it down)
If your cell # is: 101-555-1234, DIAL: 1015551234 / hit green phone.
Just follow all the voice prompts to set up your greeting message,
access & delete voicemail messages, etc..
ADD YOUR OWN NUMBER TO YOUR PHONE -- AS A CONTACT.
Place it in double parenthesis, just like this: "VOICEMAIL"
When you open phone and hit the contacts button, it will ALWAYS
be the very FIRST contact in your list of contacts. DARN HANDY!!
Kyocera Oystr... | Answered on Nov 10, 2011
For this problem contact your mobile service provider...
Kyocera Oystr... | Answered on Sep 03, 2011
DEAR PADI YOU GO BRING THE PHONE MAKE I FLASH AM FOR YOU.
Kyocera Oystr... | Answered on Jan 25, 2011
IT MAY BE HAVING SCREEN PROBLEM, SO NEED TO NEED TO REPLACE WITH NEW ONE
Kyocera Oystr... | Answered on Dec 15, 2010
Call your provider.
http://cellphoneforums.net/kyocera/t300785-i-forgot-my-lock-code-kyocera-melo-s1300.html
http://forums.wirelessadvisor.com/kyocera/14612-codes-for-kyocera.html
Kyocera Oystr... | Answered on Aug 27, 2010
The problem with your phone is just flex problem, the flex on the screen of your phone is weak or worn out, this is a common problem among slide or flip phone.
What you need to do is to replace the flex on the screen of your phone, you can get this done by going to any local phone repairer within your vicinity to help get it fix or replace.
Once the flex is replace, your phone display problem is solve and the screen will start displaying.
Take care.
Kyocera Oystr... | Answered on Aug 04, 2010
check if the time on the phone is correct, if it is, ask the sender for the original time the message was sent.because messages get delayed by the network sometimes.
if it does not correspond then the problem is from the network.
take note if it happens all the time, then you contact your customer care center for your network service provider.
goodluck
Kyocera Oystr... | Answered on Feb 03, 2010
it crapped out either the system software or the switch that recognizes when its flipped open -- shut the phone down.. crack it open a few centimeters so u can kinda see the screen i.e less than a 1/4 the way open , using a toothpick or something similar use that to press the power button, wait and the phone should load up. note allow it to completely load to the main screen and try to navigate the software while still in this position you may be able to flip it open to work it more comfortably but definately WRITE *pen/paper* your important info from the phone i.e #'s and ect.. and prepare to buy another phone
Kyocera Oystr... | Answered on Nov 26, 2009
This phone cannot recieve picture messages because it's not a camera phone. With this phone company only camera phones can recieve picture messages.
Kyocera Oystr... | Answered on Jul 30, 2009
Good Luck!
Kyocera Oystr... | Answered on Jan 03, 2009
I had same problem, I found if you do not open phone past 90 degrees from keypad, screen will stay lit and is usable, but when fully open, screen shuts off after a few seconds, apparently a faulty connection when fully open. I use mine like this, with a backstop attached to phone body to prevent it from opening more then 90 degrees, and after a few months, it is still working.
Kyocera Oystr... | Answered on Dec 23, 2008
Kyocera Oystr KX9 Cellular Phone Logo
37 questions posted
Top Kyocera Cell Phones Experts
efs_perpends
efs_perpends
David Gust
Are you a Kyocera Cell Phone Expert? Answer questions, earn points and help others
View Most Popular
Oystr Kyocera
  • Oystr Kyocera
Most Popular Question
got password phone htc t mobile g1
  • Cell Phones
