SOURCE: iLive Bar Speaker not playing sound
I have an iLive bar speaker ipod dock and it has worked great until today. The sound isn't working. You can hear that it is on, but it isn't playing music. The display works and everything. Is this fixable?
SOURCE: i have a 19 " sansul cant get my ilive sound bar
I hope this helps. You have to connect your sound bar to your cable box/satellite tv receiver. If you are connecting with composite or component cables you connect the video cables (either the yellow or the green blue and red cables) between the television and the cable box /satellite tv receiver. Then you connect the red and white audio portion of the cable between the cable box/satellite tv receiver and the sound bar. You are going from the OUTPUT of the cable box/satellite tv receiver to the INPUT on the television and sound bar. You use the function/source/input button on the sound bar to choose the space you plugged the cables into on it or listen to the radio or listen to your IPOD and etc.
SOURCE: I purchased an iLIVE ITP100B 20" SOUND BAR to
If you find out let me know also. I'm having the same problem hooking it up to my 23" tv.
SOURCE: trying to hook up an
If you want to hear the sound from all the sources (including the Playstation) thru it you will need to connect all of them to the receiver and the sound bar to the Line-Out or headphones socket of the receiver.
You will need a cable that has an 3.5mm jack at one end (for the soundbar) and 2 RCA connector at the other end (if you use the Line-Out connectors) or another 3.5mm jack and an adaptor to the large one if that's what it has (if you use the headphone socket).
SOURCE: three digit code for ilive sound bar
Hi Scott, my name is Cheri Torres and I work with the DISH Network Internet Response Team. I came across your post and wanted to help! I will list here for you the best code for your iLive sound bar and also the instructions for addressing the remote to your sound bar. I hope you find this information useful and if you have further questions please let me know!
The best code 2835
The instructions for addressing the remote.
1. Press and hold down the AUX button until all the other mode buttons light up.
2. Enter the code 2835.
3. Press the pound(#) button once.
4. Test the functionality of your iLive sound bar.
