20 Most Recent
iLive IHB603B Micro Bluetooth Stereo System with CD Player & AM/FM Rad Questions & Answers
How can I get my player to connest to my bluetooth headphones have tried several times no luck
If you have a Kindle Fire or later this is possible. Any Kindle before this model has the hardware for BT, but not any method to access the BT (bad on Amazon\'s part, but that\'s the way it is).Kindle Fire do this: Go to settings --> Wireless --> Bluetooth Turn on Bluetooth if it is not on. Now on your headset put it in pairing mode. Instructions on how to do this should have come with your headset. Once in pairing mode press Pair a Bluetooth Device on your Kindle. Your Kindle should "see" your headset and list the name of it under PAIRED DEVICES. You only need to pair the device once. Then you should be able to press the device name and if the device is near by and on it should connect to the Kindle.HTH
My speaker is static no sound
Pull battery or power cord for 1 minute. Connect and then try connecting to you source again. Bluetooth issue or connecting with 3.5mm cable?? .
How to connect my ilive 5.1 home theatre to my HDMI tv
If the TV and Unit have what's called an ARC socket, then you can purchase an ARC HDMI cable and this will pass both sound and picture between the TV and Audio unit.
If it has not, then you will need to connect the sound via either an optical cable or RF cable.
Some TV's have only one ARC HDMI socket, so make certain you get the right one!
