SOURCE: my kyocera taskalfa 180 showing
C6400 is a fixing unit error.
To reset -
Try this, enter "10871087" from keypad, You should now be in maintenance mode.
Enter "163"press "Start / Print" key.
You should see a screen that says "Execute".
Cursor / highlight "Execute".
Press "Start / Print key.
The machine will turn off and should come back to ready. If not then you need to replace the fixing unit.
I hope this is helpful,
Shawn
SOURCE: Free service manual with code
To reset -
C-TECH INFOWAYS
SOURCE: Error Code C 7460 On Kyocera Taskalfa 8000i
Developer shutter locked - open front cover and slide the developer shutter to open/unlock, restart the machine. The shutter is locked to prevent developer spilling when transporting the machine.
open the drum unit, open drum, blade. drop the damage toner, clean the the roller and charger and polish the drum then fix it again, if you cant that, then replace the drum unit, or call a technician.
