20 Most Recent Kyocera Mita TASKalfa 180 Black Toner Cartridge Genuine Questions & Answers
Hi, for what model is the problem?
Kyocera Mita... | Answered on Nov 09, 2017
Check that the registration switch lever does not jam inside the guide by pushing on it. You may have to modify the grooves that the lever shaft rides in to allow it to swing freely.
Kyocera Mita... | Answered on Sep 29, 2016
If you just had a power failure, it means the fuser has to be reset in service mode.
Kyocera Mita... | Answered on Apr 27, 2016
THAT IS A FUSER PROBLEM - FIRST OPEN FRONT COVER THEN PRESS 1087 TWICE AND TYPE 163 THEN START . IF THAT DOES NOT WORK YOU WILL HAVE TO GET THE FUSER UNIT OUT AND CHECK UPPER AND LOWER FUSE .
Kyocera Mita... | Answered on Oct 16, 2015
TYPE THE CODE 1087 TWICE THAT WILL GET YOU TO SERVICE MENUE COPY THAT 130 THEN START YOU ARE RUNING DEVELOPER NOW. WAIT TILL IT FINISH RUNING. PRESS START. YOU COMPLET IT NOW .
IHOPE THAT WORK
press1087 twice the scree will chancge to service mode type 130 then start it will run developer checking .I hope thats help
Kyocera Mita... | Answered on Oct 06, 2015
Don't attempt
Kyocera Mita... | Answered on Feb 11, 2015
Login wid ur username and existing password..then go to settings and click d change password link..type ur New password
Kyocera Mita... | Answered on Dec 12, 2014
C3100 is a scanner carriage problem... The error code indicates that the "home signal" is not reaching the main board in the required time;if its new machine check the scanner lock removed or not.other wise open platen glass and clean all optics,,if its not working check the main board,&connector cables,,,,
Kyocera Mita... | Answered on Nov 25, 2014
All new copier/printer has safety pacageging SCREW /TAPES to prevent damage in traveling/shipping w/ it your Kyocera taskalfa 180 won't print, look for it and remove it all usually it is color orange 1 of them located at Optics unit .
Kyocera Mita... | Answered on Nov 21, 2014
just open platen glas and clean the mirror,,,then clean tha laser unit also,,,then it will work,,,
Kyocera Mita... | Answered on Sep 03, 2014
Add the toner thats empty.
check registration black switch arm, spring has come off.
Kyocera Mita... | Answered on Aug 04, 2014
its code for fusing unit...you can reaset this one ,,go to service mode then 163
Kyocera Mita... | Answered on Jul 21, 2014
The manual says you have a paper jam in Multi-Purpose Tray.
It is on page 7-10
Kyocera Mita... | Answered on Jun 16, 2014
Kyocera Mita TASKalfa 180 Black Toner Cartridge Genuine Logo
Popular Tags
29 questions posted
Top Kyocera Mita Office Equipment & Supplies Experts
AAAA262430
Marvin
Marvin
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Kyocera Mita Office Equipment & Supplies
Most Popular Question
shake toner container problem
  • Office Equipment & Supplies
