Question about Kyocera TASKalfa 180 Copier
My kyocera taskalfa 180 showing c6400 error please help.
Posted by jayweira2000 on
Shawn
  • 200 Answers
C6400 is a fixing unit error.
To reset -
Try this, enter "10871087" from keypad, You should now be in maintenance mode.
Enter "163"press "Start / Print" key.
You should see a screen that says "Execute".
Cursor / highlight "Execute".
Press "Start / Print key.
The machine will turn off and should come back to ready. If not then you need to replace the fixing unit.
I hope this is helpful,
Shawn
Posted on Mar 02, 2011
  • 5 more comments
  • mahisajwan
    mahisajwan Feb 09, 2014
    C6400 is a fixing unit error. To reset - Try this, enter "10871087" from keypad, You should now be in maintenance mode. Enter "163"press "Start / Print" key. You should see a screen that says "Execute". Cursor / highlight "Execute". Press "Start / Print key. The machine will turn off and should come back to ready. i tried thanks sir
  • kaleem
    kaleem Jun 20, 2014
    kyocera taskalfa 180.... How to disable power saver mode
  • Muhammad Ali abbasi
    Muhammad Ali abbasi Aug 18, 2014
    very very useful and helpful taskalfa 520i
  • TEGUH KARYA cv
    TEGUH KARYA cv Sep 09, 2015
    thanks a lot broo very helpul
  • Anonymous Apr 27, 2016
    10871087 press 163 but not srart
  • Regina Francis
    Regina Francis Nov 27, 2017
    THANK YOU FROM KENYA
  • laban kibidi
    laban kibidi May 11, 2018
    it worked ....its a 30 seconds process
DAVD Gunarathna
    New Friend:
  • 3 Answers
M y kyocera taskalfa 180 showing error code c6400
Posted on Jul 15, 2013
ahmed_beloua
    New Friend:
Erreur c3100
Posted on Aug 03, 2012
mutunga_robe
    New Friend:
Kyocera Taskalfa 180- machine paper jamming and slow
Posted on May 11, 2011
shaiju_poozh
Thanks alot.. Its working..
Posted on May 19, 2015
How can I fix the error c6400 on kyocera taskalfa 221?
Hi
I found this explanation of your error, although my understanding of it is not entirely clear.
Code: C6400
Description: Zero-cross signal error
Interrupt of the zero-cross signal does not occur more than 1 s.
Causes: Poor contact in the connector terminals.
Defective power source PWB.
Defective engine PWB
You can find this here:
Error Codes Kyocera Mita TASKalfa 221 Code C6400
and also by changing the drop down menus along the top of the page you can view other errors for your machine and for other models and makes. You can also use the link to get a Service Manual for your machine.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Dec 17, 2014 | Kyocera Office Equipment & Supplies
ADD TONER ERROR
Good day, if your error is toner then make sure the small white gears on the back of the toner cartridge is turning, if they are not then replace toner bottle, if they are turning ask a technician to test the toner motor. If your machine displays error C6400 then enter service mode by pressing 10871087, now press 163 and OK, now restart your machine, if the code is still there then you should replace your fuser/fixing unit.
Apr 03, 2014 | Kyocera TASKalfa 180 Copier
Light flashes hit button prints
my kyocera taskalfa 180 showing error code c6400 please help.
Jul 15, 2013 | Datamax Ex2 Thermal Label Printer
My kyocera taskalfa 180 showing A2400 error please help.
c4200? a c4200 is a laser unit error. replace lsu.
Mar 30, 2013 | Kyocera TASKalfa 180 Copier
My kyocera taskalfa 180 asking me to call service C6000. How can fix this error?
My kyocera taskalfa 180 shows an error.call service c6000.what should i do
Jun 30, 2012 | Kyocera TASKalfa 180 Copier
My kyocera taskalfa 5500ci showing error code C6600. please help
Please refer to the manual for error code listing and describe the error here can help
Aug 18, 2011 | Kyocera TASKalfa 180 Copier
Kyocera -taskalfa 180- service call c6400
I can't solved the problem with the cited solution reference . pliz help
May 07, 2011 | Kyocera Office Equipment & Supplies
Free service manual with code for kyocera TASKalfa 180
Pls. send Free service manual with code for kyocera TASKalfa 180.
My email [email protected]
Especially interisuet off hibernation.
Aug 05, 2010 | Kyocera TASKalfa 180 Copier
Kyocera TASKalfa 180 Copier Logo
8,481 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Tareq Bin Mostaq...
Tareq Bin Mostaq...
CheckitRight
CheckitRight
Marvin
Marvin
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
