SOURCE: access ip address inofmation page on aficio 3224c
Type the IP address of your machine into your web browser. Login to Administrator Mode as follows:
Username: admin (or possibly "administrator")
Password: (leave blank)
SOURCE: Hello!
please check with your head cleaning and also your ink cartridges. if low replace and reset. If fault is still on, then reinstall the printer software and restart. . Please also check on your connection cords. See if any paper is jammed or is obstructing the mechanism, check carefully. i hope you get this fault. good day
SOURCE: Ricoh aficio 3224c error sc570
Insufficient oil (the oil tank in the rear of
the machine)
Testimonial: "se recargo el tanque de aceite pero el aceite no fue detectado por el sensor."
SOURCE: ricoh aficio Aficio 3224C used
On a 3224, the used toner bottle is easily replaceable. To get to it, open the front cover of the copier. In the lower left corner, you will see a white or light gray plastic container which slides straight out -- that is the used toner bottle. You can replace it (if you have a new one) by taking the old one out, putting the black plug in the hole to prevent toner from spilling, throwing it away, and inserting the new bottle. If you don't have a new used toner bottle, you can empty this one out into a large bag or trash can and then reinstall it.
the machine)
