Re: Hi
i have ricoh 3010 is there any option bypass?
It does have by-pass option, but is as additional unit and on your machine can be installed. You can check does it have it on right side attached in the duplex unit. Under the driver need to be checked for print driver to know that the machine have by-pass unit.
Due to a control error, a RAM overflow occurred during system
processing
Possible Causes
• System program defective
• Controller board defective
• Optional board defective
• Replace controller firmware
Have you replaced the developer yet???? It could also be the unit that the toner bottle goes into. There is a paddle wheel inside of it that move the toner and it may have broken up... Good Luck
when the toner supplied to u it come with two caps one is of black colour and other is of white colour. black u took out and u have added the toner some times white cap do not opened in he machine. u just take out the white cap and toner will b added
there are two places to set the paper tray on the ricoh aficio 2035 print drivers first make sure you are using the PCL 5 drivers not pcl6 or rpcs then go to the printers folder and set the defaults by right clicking the printer and selecting properties printing preferences, then go into word and select print set up and properties then defaults for printer select bypass tray and select labels enter the correct sheet size for the labels from the drop down box click apply and you should be set.
if this resolves your issue please rate my anser accordingly
That's strange. I just downloaded it to see what might need to be done, and the bypass tray was available, and it's a standard feature, so it doesn't have to be manually added or anything. I, however, used the Ricoh driver which is identical, because Ricoh owns Gestetner (in case you didn't know) so you may try installing that one. maybe it's a glitch in the Gestetner driver package. The comparable model is Ricoh AP 4510, and you can get it here. I hope this helps:
You should just be able to place paper on the tray and then select the bypass tray under "properties", "Paper", then under "tray" select "bypass tray" when printing.
