SOURCE: freezer stops and start
ice cream is always the last to freeze and a temp of minus -10 degrees is usually required to get it to get hard. if you put the ice cream in the door it will be especially tough to freeze. a good thermometor is a good investment as you can observe the temps. usually ten degrees or 20 degrees is what they run. yes they do cycle on and off as long as they hold temps thats good. the outside of the freezer gets warm because the hot compressed refrigerant is spread through piping near its surface giving up its heat of compression . setting the stat to max will freeze the ice cream eventually but utility bill suffers . good luck
SOURCE: chest freezer won't restart
Probably bad thermostat- jump it out and see if it starts. I cannot see your repyl due to some tech issue w/ the site, so it may be a day or so before I can reply again. Please leave feedback for me if appropriate. Thanks
SOURCE: Problem with Maytag Chest Freezer model MQC1557aew.
First make sure than the condensing coil in the freezer is clean of dust and dirt(it is behind the grill vent in the bottom side of the freezer where the compresor is) If it is clough brush the dirt off after you unplugit.When is clean wait a few minutes ,5, and plugg it back at the GFI outlet and see if work If still tripped the outlet you may have to replace it.
SOURCE: My Electrolux TC75 Chest Freezer wont even get cold
well one thing to know if the thermostat is working and if the gas is really enough to allow the unit run well.
SOURCE: Both springs on lid broken. Lid won't stay up.
Whatever is on the shelf (parts that have not sold yet) is your best bet. Someone in the USA has to have em cause it hasnt been that long out of business.
here's one place to start ( i couldnt get thru)
AJ Madison
1416 38th Street
Brooklyn, NY 11218-3614
Phone:
800-570-3355
718-532-1800
Phone:
800-570-3355
718-532-1800
Fax:
800-570-7805
E-Mail:
[email protected]
Appliance
Parts Store:
800-378-5177
Appliance parts store:
1800- 378-5177
hope this helps
Hello Cory Mitchell - If your freezer is not cooling, it could have a floating restriction in the lines or something more complicated like an issue with the seal system that only a professional can repair. This can conclude the compressor not working correctly, the evaporator fan not turning, or even coolant in the lines at incorrect levels to properly cool. If the compressor was running, humming or even a little warm then that was typically normal. Also try checking and see if the door seal is bad; place a dollar bill between the body of the freezer and the door. Now close the door. The dollar bill should stay in place and pull out with a small amount of resistance. If the dollar bill falls out when placed between the gasket and cabinet double check to see if the door is being blocked by anything stopping it from closing. If it proves to be ineffective, connect with a professional to accurately pinpoint any potentially more serious issues.
