20 Most Recent Magic Chef Chest Freezer MCCF5WBX Questions & Answers
Sounds like slow Freon leak. You might get an estimate over the phone before calling a technician, but I would think a 3-year old box is worth repairing. If the estimate is close to the replacement cost, that might not be the case.
Magic Chef Chest... | Answered on Feb 25, 2018
Feel compressor to see if running and warm. If not, most likely thermostat control is bad. If it is running, determine if it runs continuously or if it's clicking on and off every couple minutes. If clicking on and off, replace overload and relay that plugs into side of compressor. If running continuously, there is probably a freon leak on blockage. Replace freezer in latter scenario
Magic Chef Chest... | Answered on Nov 05, 2017
Roughly measure the diameter of the hole and add an 'M' in front of it. My guess would be something like M8. One trick is to get a piece of white paper and press it against the hole with your finger. It should leave a dirty imprint of the size of the hole. Take that to a fixings supplier. Or you could just take the top in.
Magic Chef Chest... | Answered on Dec 01, 2015
First your freezer does not use R-134a. That is for auto air conditioners only. It uses R-12. You need refrigeration compound gauges, R-12 refrigerant and a two devices that connects to and punctures the lines and gives you a port to connect the hoses from the refrigeration compound gauges. You must have a refrigeration leak if you need to add refrigerant. The leak needs to be repaired or you will lose the refrigerant in a short time again.
Magic Chef Chest... | Answered on Nov 08, 2015
No check your settings. You may try to unplug it for about a minute and then restart. If that doesn't work, call the mfr. they should help since it is new.
Magic Chef Chest... | Answered on Jan 16, 2015
Could be your thermostat is bad and not calling for the compressor to come on. If you are able see if there is power getting to the compressor. If not then back track to where you are loosing power (thermostat) etc.
Magic Chef Chest... | Answered on Nov 11, 2014
should be another mesurement
Magic Chef Chest... | Answered on Aug 31, 2014
Motor burnt-out, leakage, failed circuitry or temp-sensor ...
Magic Chef Chest... | Answered on Jul 17, 2014
Magic Chef Chest Freezer MCCF5WBX Logo
89 questions posted
Top Magic Chef Freezers Experts
Muntejaya Ginting
Muntejaya Ginting
Arnie Burke
Arnie Burke
Andrew Taylor
Andrew Taylor
Are you a Magic Chef Freezer Expert? Answer questions, earn points and help others
View Most Popular
Magic Chef Freezers
  • Magic Chef Freezers
Most Popular Question
fast freeze light all time right new
  • Freezers
