20 Most Recent Woods Chest Freezer C1501W3 Questions & Answers
Both light flickering probably indicates a problem with the plug or the cord. If it was just the inside light I would suspect the door switch, but both light would indicates an open short in the wires or plug.
Check the plug connection at the wall and see if it is loose. While unplugged check the cord for any nicks or cuts. Plug something else into the same wall receptacle , like a light and see if the power to the receptacle is ok.
If none of the above work then it is time for a qualified repair person.
J
Woods Chest... | Answered on Feb 20, 2018
I would try replacing that overload and relay in the compressor. Your compressor may be shorted out. If it is, replacing relay and overload won't help.
Woods Chest... | Answered on Oct 01, 2017
lever off the plastic cover, unscrew and replace the lamp
Woods Chest... | Answered on Dec 18, 2015
Depending upon the internal circuitry, the indicator may flash until a set temperature is reached.
Woods Chest... | Answered on Jul 17, 2014
Is it more than 10 years old?
Woods Chest... | Answered on Mar 14, 2014
Try a APPLIANCE PARTS/REPAIR shop..... If they can not get it for you, it can not be gotten....
Woods Chest... | Answered on Jan 17, 2014
Wash it out with a mixture of 1 ounce ECO friendly bleach mixed in 1 quart of hot water.
Woods Chest... | Answered on Feb 19, 2013
The hole is for cleaning and draining. It has little effect on the temp.. Do you have to put bottles inside? To start with, liquids expand as they freeze and get hot. Anything below freezing is going to give you a problem. The colder, the sooner it will break the bottles.
Woods Chest... | Answered on Jan 30, 2013
Yes, the freezer temperature means the lid gets very cold. Every time you open it some moisture condenses in the lid and the outside ambient also affects it. The insulation may be beginning to break down and the ice is forming inside. It is not a major problem however and many freezers go on for years with freezing lids!
Woods Chest... | Answered on Apr 20, 2012
wc Woods is out of business however sears.com lista woods parts. Good luck.
Woods Chest... | Answered on Apr 02, 2012
The problem is with lamp holder. You should remove the covel and reach for the lamp and remove it. First remove the power cable of freezer. Now try to bend the center back contact of the lamp holder which is actualy not making good contact with the lamps back contact point. You can use also a wire brush, or a glass paer to clean the contacts of bothe the holder and lamp. Also it may be nessesary to use a new lamp since sometime their contacts are melt a litle bit and they loose contact. In the worst case you may need a new lamp holder.
We have here a link with your model parts diagram, if the model differs then you make a research with correct model so you can have correct leyout.
Woods Chest... | Answered on Aug 11, 2011
No it is not normal. But it is an easy fix! Clean the condenser grill and make sure that the compressor fan is working.
When the condenser grill is dirty it can't get rid of the heat from the compressor, so it transfers the heat to the cabinet. Also make sure that you have air space behind your unit and it is not crammed against the wall.
Note: If this is in your garage or in a closet, suggest you put it up on 4x4 blocks so that it can get plenty of air flow around it and you will even save some electricity since it won't have to work so hard.
Woods Chest... | Answered on Aug 08, 2011
It's normal to touch it hot on the outside front.
Because it has heater to keep moisture out in the body metal of the freezer.
Those moisture if not heated to dry, can cause rust build up.
Rust build up can destroy the metal body of the freezer.
Thanks for asking.
Woods Chest... | Answered on Jul 01, 2011
Chest freezers are manual defrost. Which mean yall unplug it to defrost it.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Woods Chest... | Answered on May 13, 2011
Woods Chest Freezer C1501W3 Logo
43 questions posted
Top Woods Freezers Experts
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you a Woods Freezer Expert? Answer questions, earn points and help others
View Most Popular
Woods Freezers
  • Woods Freezers
Most Popular Question
hole innside freezer
  • Freezers
