You can purchase a wide variety of high quality Holmes replacement parts for your Holmes Air Purifier direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
It's attached to the pulse radio-wave ionizer. It comes on when the unit is on to show the radio wave is working. It's not needed and I've never seen a replacement but Radio Shack could probably help you replace it if you wanted.
The high-voltage grid wire(s) most likely broke -- unfortunately, there is no good remedy for this -- I have repaired a half dozen of these units by replacing the grid wires with titanium wire. This is a very time-consuming, complicated, nerve-wracking repair -- not recommended. Even if the reapair is done, the unit will likely fail again, soon.
When my reapired units failed, I got units off E-Bay -- they didn't last very long either.
I'm now in the market for a more rugged ozone-generating air purifier.
This is a repair that someone I know didafter reading a post on the net.....regarding Quadra repairs....and here is a link for repairs....its all one link....so type it into your browser or paste it.....
Gently remove the top as there are wires connected to it.
Once removed, find the microswitch assembly on the side. There will be 2 green wires going to this assy board (PCB).
Examine the bottom of this board. On both my units, the PCB wascorroded badly on the trace that runs from the center lead to the wireconnection. This will cause the microswitch to quit working.
What I did was soldered a wire from the center contact of themicroswitch (center piece coming through the board. There should be alarge solder pool) to the wire connection at the edge of the board.This just 'goes around' the corroded PCB trace.
Worked fantastic on both ionic breezes and took about 5 minutes for thesecond one. The first one took over 2 hours just to find the problem.
I hope this helps.....good luck...thanks for rating my effort....the Fang.
