Remove the control panel and try to clan the board using isopropyl alcohol using a brush. Leave the board for one day so that it would get dry. Then install the control board back and check and check it. Sometime moisture acclimated on the control panel can cause such problems . If you didn't get isopropyl alcohol then put the control board in sunlight for one or two days. Then install the control panel and check whether it works or not. also try to replace all the switches on control panel board. you will get it in any electronic spare parts shop.Beside not to put it on direct sunlight it can cause problems to the display
If you wish to get some more details about treadmill repair then check the following link.http://electro-medical.blogspot.com/
