20 Most Recent Nordic Track NordicTrack C900I TREADMILL NORDICTRACK Questions & Answers
Most buttons (all but incline 6 through 12) on my C900i stopped working all of a sudden. Long story short... it was the ribbon cable connections on the back of the control panel. Its 6 screws to get the panel off, and then 10 screws to open the panel. Cut the zip tie so the connection wires can be pulled through the hole in the back panel cover. And then take the iFit module off after you open the panel to allow fully removing the cover. The little white piece on the ribbon cable connectors slides up to allow the cable to slip out. Search youtube if you've never dealt with ribbon cables/connectors - they're very common in electronics. You can also search for how to clean the cables. In my case, simply disconnecting/reconnecting was all I had to - this fixed every button on my panel.
Nordic Track... | Answered on Mar 29, 2020
cleal the contacts relais, and replace if necessary. Of course your LUBE the gear and shaft too.Test the elevation motor for problem bearing for repair.
sincerely. God bless you
Nordic Track... | Answered on Jun 23, 2020
https://www.audiusa.com/content/dam/audiusa/brochures/2019/2019_Audi_Q7_QSG.pdf
Nordic Track... | Answered on Apr 10, 2020
https://www.manualslib.com/manual/583110/Nordictrack-Commerical-2450-Treadmill.html?page=27
Quoting from manual above (may be similar model if not the same.)
7. Turn on or turn off the display demo mode.
The console features a display demo mode,
designed to be used if the treadmill is displayed
in a store. While the demo mode is turned on, the
console will function normally when you plug in
the power cord, press the power switch into the
reset position, and insert the key into the console.
However, when you remove the key, the screen will
show a demo presentation.
To turn on or turn off the display demo mode, first
touch the Demo Mode button. Next, touch the On
checkbox or the Off checkbox.
Nordic Track... | Answered on Mar 06, 2020
Nordic Track NordicTrack C900I TREADMILL NORDICTRACK Logo
Popular Tags
10 questions posted
Top Nordic Track Exercise & Fitness Experts
Marvin
Marvin
Jesse Garza
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
View Most Popular
  • Nordic Track Exercise & Fitness
Most Popular Question
only plus button console works
  • Exercise & Fitness
