The treadmill Nordictrack A2050, will not do anything, with the key in place?
1) test the receptacle wall, plug a desklamp for to see if work if is working go
2( testing the power cord for open or defective.
3) reset the machine
4) test the fuse for blown and replace
5) test the c.breaker for tripped and reset again.
6) test the key, the key is small magnet, you can test with your magnet refrigerator with atraction or repulse, if doesnot replace the magnet from home depot.
God bless you
SOURCE: Nordictrack motor will not run when start button is pushed.
Likely the cover of one of the motor brushes popped off. Unplug the machine before you pop it back in place, then try it again.
If that doesn't work, most likely it's the motor control board, or possibly the console, or finally just a loose connection behind the console.
But most likely, it's the motor brush cover. I've been seeing that alot with this model.
SOURCE: My nordictrack solaris treadmill will not
Check connections on the console, motor control board and the brush covers on the motor.
SOURCE: I NEED THE NORDICTRACK 9600 INCLINE TRAINER TREADMILL SCHEMATIC
contact me @ [email protected] I will send this to you.
SOURCE: NordicTrack Z7xi treadmill console buttons not working
Hello there. It sounds as if you may have a button stuck on your console. Thus not allowing any other buttons to be pushed. (i.e. the 4 beeps). This is usually caused by the i-fit buttons (silver buttons on the front). If the machine is only 4 months old you should still be under warranty (1 year) I believe. This problem in most instances requires the console be replaced. You can contact nordictrack through iconservice.com or by using the number on the fron of your users manual.
Good Luck! Tim
