20 Most Recent Nordic Track NordicTrack A2350 Pro Treadmill Questions & Answers
Check the drive belt. It may be loose or broken. If the belt is loose, then to tighten the drive belt, start by removing the front cover. loosen the bolts around the motor then tighten the drive belt by tightening the motor adjuster bolt. Once the drive belt is tight, tighten the motor back down.
Nordic Track... | Answered on Apr 16, 2016
1= Not rexactly, however you must LUBE the deck belt, this a problem because of lack of maintenance, probably a deck worn, this cause enough friction shut down the machine for protection electronic.
2)LUBE the rollers bearing.3)test the input voltage motor, if there are the motor need repair.4) measure the output voltage board, if there are NOT voltage, the board is faulty, see my personal TIPS, and see the block diagram. RUN the software calibration for diagnose, and troubleshooting.
God bless you
Nordic Track... | Answered on Apr 12, 2016
Hope the speed sensor have some problem may dust on it or the treadmill need lubrication. Most of the treadmill stop after some kilometres reading indicating that its time to lubricate it. After lubrication you have to reset the counter.
check the link bellow using the search tab find out details of NORDICTRACK A2350. and follow those instruction.
www.electro-medical.blogspot.com
Nordic Track... | Answered on Nov 02, 2015
I would think so sometime what does the manual tell you
Nordic Track... | Answered on Feb 17, 2015
Either a faulty Motor Controller Board or Motor.
Disconnect the power lead.
Disconnect the Motor from the Controller board.
Then reconnect the power lead.
Press 'start' and see if this trips the electrics.
If the electrics trip when the Motor is not connected to the Controller board, then the Controller board is faulty.
Disconnect the power lead then test the Motor.
Try running the Motor with a Drill Battery, connected to the Motor leads.
These tests should only be done if you are competent to carry out the tests.
Caution at all times Lethal Voltages are present
SAM Fitness Solutions
Nordic Track... | Answered on Oct 24, 2014
Nordic Track NordicTrack A2350 Pro Treadmill Logo
52 questions posted
Top Nordic Track Exercise & Fitness Experts
Marvin
Marvin
Jesse Garza
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
View Most Popular
  • Nordic Track Exercise & Fitness
Most Popular Question
treadmill incline works belt not move
  • Exercise & Fitness
