20 Most Recent Nordic Track NordicTrack Elite zi Treadmill Questions & Answers
Dear Sir:
Thank you by your problem, I will help you inmediately.
Make sure that the power cord is plugged into a surge suppressor, and that the surge suppressor
is plugged into a properly grounded outlet . Use only a single-outlet surge suppressor
that is UL 1449 listed as a transient voltage surge suppressor (TVSS). The surge suppressor
must have a UL suppressed voltage rating of 400 volts or less and a minimum surge dissipation
of 450 joules. The surge suppressor must be electrically rated for 120 volts AC and 15 amps.
Important: The treadmill is not compatible with GFCI-equipped outlets.
2)After the power cord has been plugged in, make sure that the key is fully inserted into the console.
3)Check the circuit breaker located on the treadmill
near the power cord. If the switch protrudes as
shown, the circuit breaker has tripped. To reset the
circuit breaker, wait for five minutes and then press
the switch back in.
4)Check the on/off switch located on the treadmill
near the power cord. The switch must be in the on
position.
I hope you resolve this. Otherwise, try to reach me. Inmediately.
sincerely.
E.Cuadra
Nordic Track... | Answered on Jun 09, 2017
1) test the outlet wall , put a desklamp and see if work, if work the problem will be in the machine,
2) test the fuse inside for blown and replace with the same capacity
3) reset the circuit breaker inside.
4) test the power cord for open or defective.
Try again, if the machine NOT work, the problem will be in the power supply see the block atached.
God bless you
Nordic Track... | Answered on Sep 20, 2012
sensor bad dirty or out of adjustment
Nordic Track... | Answered on Sep 06, 2012
Sensor is out of adjustment, follow wires and check to see if limiter sensor has been moved or is loose
1) you must adjust the REED switch, clean it and tight the wires connector very well.See the diagram
2) when you fix it, RUN the software calibration for diagnose, troubleshooting and fix it.
God bless you
Nordic Track... | Answered on Jul 14, 2012
Nordic Track NordicTrack Elite zi Treadmill Logo
69 questions posted
Top Nordic Track Exercise & Fitness Experts
Marvin
Marvin
Jesse Garza
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
View Most Popular
  • Nordic Track Exercise & Fitness
Most Popular Question
nordictrack exp1000 incline will
  • Exercise & Fitness
