FoodSaver 2-IN-1 Preservation System 4400 Series Logo
Linda Bertrand Posted on Jul 31, 2016
I have a foodsaver v4400 It has been working fine, but all of a sudden the Accessories Retractable Handheld Sealer stopped working, the regular sealer part still works.
There is no suction in the tube. This is the second v4400 that we have bought in less than 3 years. The same thing happened to the first one, We took some on line advice and took it apart
My FoodSaver will not activate when I insert a bag. The accessory unit works fine.
It sounds like you are having some issues with your FoodSaver vacuum sealer. Here are a few things you can try to troubleshoot the problem:
  1. Make sure that the FoodSaver is plugged in and turned on.
  2. Check the sealing strip on the vacuum sealer to make sure it is clean and free of debris. A dirty or damaged sealing strip can prevent the vacuum sealer from working properly.
  3. Check the vacuum bag to make sure it is properly positioned in the vacuum sealer. The bag should be inserted with the open end facing the sealing strip.
  4. Make sure that the bag is not too full. Overfilling the bag can prevent the vacuum sealer from working properly.
  5. If the problem persists, you may need to take the FoodSaver to a repair center for further diagnosis and repair.
Sep 21, 2022 • Vacuums
It won't vacuum. Why?
vacuum sealer won't pull vacuum - GardenWeb
forums.gardenweb.com > Garden Forums > Harvest
Nov 9, 2008 - I know many of you use vacuum sealers, so hope you might be able to help. I have a FoodSaver Pro Sport, it's probably about three years old.
How to fix Food Saver - Vacuum Sealer? - Instructables
www.instructables.com/.../How-to-fix-Food-Saver-Vacuum-...
InstructablesMar 2, 2012 - I have a Food Saver brand Vacuum Sealer, that all of a sudden stopped ... If it won't heat up to seal the bag, then you probably have a break in
vacuum sealers - Frequently Asked Questions
1helpful
2answers
Why there say tray full red light
The tape trick didn't work for me. Had to cut the wires. Works for now.
17helpful
3answers
Foodsaver V845 is not sealing? vacuums okay, but won't seal bag.
Does the vacuum seem to run forever and it doesn't seal?
Clean the black foam seals
Replace them if needed. they can be purchased from Tilia
WWW.FOODSAVER.COM
Top FoodSaver Kitchen Appliances - Others Experts
john h
ADMIN Andrew
ADMIN Andrew
vince
Are you a FoodSaver Kitchen Appliances - Other Expert? Answer questions, earn points and help others
