Question about FoodSaver Vacuum Food Sealer - V3840
Door to my foodsaver is stuck on one side. It's shut. How can I release it? Is there a release button anywhere?
Posted by Roar on
Claude Kayser
    Top Expert:
  • 9,098 Answers
Trouble with Food Saver Brand - Survival Podcast
thesurvivalpodcast.com > ... > Food Preps > Processing Food For Storage
Aug 15, 2010 - 17 posts - ‎13 authors
We have been using our Food Saver Vacuum sealer we bought ... connects somehow got stuck open and therefore the bags would not ..... I've had the FoodSaver V3840 for about 10 months now and thus far it has been great.Missing: door
FoodSaver Repair - YouTube
? 8:22
https://www.youtube.com/watch?v=jguFiF0Rouw
May 21, 2014 - Uploaded by Kelly Kimble
Repair a FoodSaver that isn't drawing out air anymore. In this case, its ... Vacuum Sealer Troubleshooting - Duration: 10:25. katzcradul 52,345 views. 10:25 ... How to Food Saver Lemon Juice or Other Liquids - Duration: 4:56.
[PDF]Use and Care Manual - Home Depot
Posted on Jan 25, 2016
Stuck closed, how to open?
press release on top cover , I had someone use mine 1ce and they pressed "seal" with no bag in machine it did exactly that it stuck closed, tight too !! one touch of release button on top cover and it popped open
Jan 15, 2016 | FoodSaver V3250 Vacuum Sealer Kit
Door lock is stuck closed cannot shut door?
Good Morning Richard, thank you for your inquiry!
Based off the information you have provided your Frigidaire oven door is stuck closed and you are unable to shut the door. You can disconnect power from your range for at least ten minutes and that will reset your oven. This may trick your door latch into opening.
You can also hold down the cancel or clear button for 10 to 15 seconds that may allow your door latch to release. Also attempt to hold down the light and cancel buttons. I hope this information has been helpful to some degree. -Matt
Mar 23, 2015 | Frigidaire Ovens
How to release a disc from laptop button stuck
Most cd or dvd in computewrs have a small hole them in the door. You will need a paperclip. Straighten it out insert the paerclip into the hole and push gently but firmly. This will open the door up and allow you to retrieve the disk
Aug 19, 2014 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
Where the gas latch release button is located in the 2003 ford escape
my fiance says it should by the door on the drivers side
Feb 16, 2014 | 2003 Ford Escape
FoodSaver v3825 (I believe it's the same as the v3840) will not pivot open so I can clean the drip tray - the release buttons are releasing, but it is hung up on something.
Mine did that when I interrupted the cycle. I plugged it in and let the motor fully open the sealing chamber then I was able to pivot open the machine.
Sep 05, 2010 | Sunbeam JARDEN FoodSaver V3840 Upright...
My gas flap is stuck closed. We had to pry it open yesterday to fill the tank. 2 months ago the same thing happened, but it has worked since then.
If you have fuel door release cable & door is open, verify that cable moves in & out when you activate it. If yes you can adjust tab that it rests on so it will release properly. Just bend tab slightly inward at first, till it releases correctly.
Jun 14, 2010 | 2002 Volkswagen Passat
Can't open my foodsaver for cleaning
I had the same problem and got this information from Foodsaver:
Turn Foodsaver unbit on and press the cabncel button. That should release the unit for cleaning.
It worked for me!
Feb 02, 2010 | Tilia Foodsaver V835 Vacuum Sealer
The Foodsaver V3460 will not open for cleaning. The left side appears to be releasing, but not the right. Your assitance is appreciated. Thanks, Steve
Just plug your unit back in and press the stop button, then it will release it automatically when you press the 2 green buttons, took a while for us to figure it out.
Oct 17, 2009 | Tilia Foodsaver V835 Vacuum Sealer
PASSENGER REAR DOOR WILL NOT SHUT STUCK OPEN?
hello,seems your door brake is stuck-up,remove your door siding,then put some grease or replace your door brake,ty
Apr 26, 2009 | Mercedes-Benz E-Class Cars & Trucks
FoodSaver Vacuum Food Sealer - V3840 Logo
1,832 people viewed this question
Top FoodSaver Kitchen Appliances - Others Experts
Marvin
Marvin
Andrew Taylor
Andrew Taylor
Jim Busse
Jim Busse
Level 1 Expert
Are you a FoodSaver Kitchen Appliances - Other Expert? Answer questions, earn points and help others
