Question about FoodSaver Vacuum Sealer Kit V3460
My Foodsaver V3460 will not Vacuum my bags. It Seals fine, but will not vacuum. What can I do?
Posted by Bobbie Matthews on
  • Bobbie Matthews
    Bobbie Matthews Mar 10, 2014
    I've had my FoodSaver Vacuum Sealer V3460 for a little over a year and have never had trouble with it. I only use it about once a month and clean it every time I use it. I pulled it down to use it and found that it Seals fine but will not vacuum. I've checked all of the parts and there are no crumbs or particles that would be blocking it. The machine knows when I put a bag in and it starts the process to Vacuum, but it doesn't pull the air out. Is there something else I could check for or is there a part that is possibly bad inside?
gotyacovered
    Problem Solver:
  • 9 Answers
Foodsaver vac 1050
Perhaps the bags you are using are not suitable. If they are too thin it will not vacuum air out.
Apr 30, 2018 | FoodSaver Vac 800 Vacuum-Sealing Kit,...
Cannot get it to vacuum.
Does it try to vacuum but never flattens the bag? Make sure the bag you are using is completely sealed on the opposite end. Otherwise, the seal on the sealer is probably allowing air to leak into the sealer. If it has a foam sealer, I've found it sometimes helps to run the foam sealer under water, squeeze out the excess water, reinsert the foam sealer (make sure it is seated all the way) and then try again to seal the bag.
Mar 07, 2016 | FoodSaver Food Saver Vacuum Sealer...
Seals but won't draw all the air out. Seals fine
That could be a bad foam seal not completing suction, A piece of debris that got sucked into vacuum line and or in pump, or in some cases a crack in a elbow or pump housing.
Jan 22, 2016 | FoodSaver Vacuum Sealer Kit V3460
Foodsaver V3840 Won't vacuum air out and wont go to seal. A label states the seals are not removable. Do you know how to fix?
you are not using a "good" bag. Make sure there are no holes and that the bottom and sides of the bag are properly sealed. It will run all day and not pull the air out if the seal is broken anywhere.
Sep 11, 2014 | FoodSaver V3840 Vacuum Packaging System
FOODSAVER V3880 DOESNT GET GOOD VACUUM IN BAG
Sounds like the foam seals are leaking. Go to their website to get replacement parts.
Mar 11, 2014 | FoodSaver V3880 Vacuum Sealer - The Master...
It won't seal it doesn't get hot it vacuums ok
There is a heating element in your unit that seals the bags. Most of the units you cannot replace the heating element. The company is pretty good about warrantying the units. They go by the number on the plug to tell if the unit is still in warranty. Give them a call. 877-777-8042
Jan 19, 2014 | FoodSaver V2222 Vacuum Food Sealer
Why there say tray full red light
The tape trick didn't work for me. Had to cut the wires. Works for now.
Sep 27, 2012 | FoodSaver Smart Seal Vacuum Sealer V3825
No suction to seal bag
is a hose unplugged? Unplug the devise and see if you can find anything that looks like it's not connected OR it has a hole in the hose.
Sep 07, 2012 | FoodSaver Vac 800 Vacuum-Sealing Kit,...
FoodSaver Vacuum Sealer Kit V3460 Logo
1,537 people viewed this question
Top FoodSaver Vacuums Experts
ray gallant
Larry Ng
Larry Ng
Lawrence Oravetz
Are you a FoodSaver Vacuum Expert? Answer questions, earn points and help others
