Question about FoodSaver Kitchen Appliances - Others
Heating element not working on Foodsaver V845. What can be done?
Posted by Kim Kauper on
Marvin
    Top Expert:
  • FoodSaver Master
  • 85,239 Answers
Try a local small appliance repair shop for help.
Posted on Nov 19, 2017
5 Related Answers
Anonymous
SOURCE: foodsaver compact vac 550 sealing strip doesn't seal
My machine stopped working because the sealing ribbon was broken and the tape was worn. FoodSaver no longer does repairs. I knew the wire was called nichcome ribbon so I searched that. I checked the resistance of the ribbon on my machine, it was about 3.8 ohms. I found a site called mpakonline.com and from their site I bought 1/16 x .005 nichrome ribbon and 3/8 x 5 MIL. x 18 YD Acrylic Teflon Tape. The total cost of these items was about $36.00, the ohm value of their ribbon was 1.66 somewhat less.I used ends from radio shack made the repair and it has been working fine for the last two months and I have enough material leftover for about ten more repairs.
Posted on Feb 20, 2009
Lee Eismann
  • 88 Answers
SOURCE: Foodsaver Food Sealer Vacuum V2240 T: Foodsaver Professional II Turbo. Vacuum pump work...
This is likely happening because the unit cannot detect that a vacuum has formed, and as a result, the unit never "turns on" the heating element to seal the bag, with the gaskets around the vacuum channel being the probable culprit. The Foodsaver gaskets will deform and/or dry out with time, just like in any device, but you don't necessarily have to replace them. I've tried this inexpensive solution on my own Foodsaver V2490, and it works perfectly.
Buy some food-grade silicone grease and apply it to both the upper and lower gaskets. I remove the gaskets and coat both sides with a thin layer of grease before replacing them in their respective channels. And since this grease will be absorbed and/or dry out with time, you will have to do this occasionally, so I also flip the gaskets (i.e. turn them over) whenever I apply the grease.
You can buy a 2 oz container of silicone grease at any dive store, or you can buy it over the Internet by searching for "Trident silicone grease".
This is a link where you can buy it for around $7.00:
Dolphin Dive Center
I do not work at this dive center, but I am a scuba diver and already had some grease that I use for the numerous rubber gaskets in my gear. The 2 oz. jar will last you several years, and you will find many other uses for it around the house since the grease will last longer than a spray.
Posted on Aug 02, 2010
elementsandt
  • 10 Answers
SOURCE: i need a new heating element
Go to www.elementandteflon.com and give tthem measurements and they can make a custom element for you.
Posted on Dec 14, 2010
Ed Mac
  • 731 Answers
SOURCE: foodsaver V845 is not sealing?
Does the vacuum seem to run forever and it doesn't seal?
Clean the black foam seals
Replace them if needed. they can be purchased from Tilia
WWW.FOODSAVER.COM
Posted on Jan 24, 2011
Gil Shultz
  • 3388 Answers
SOURCE: Foodsaver V845 will not seal. it runs with no vacuum
You either have a leak or a bad pump.
Posted on Dec 31, 2016
It won't seal it doesn't get hot it vacuums ok
There is a heating element in your unit that seals the bags. Most of the units you cannot replace the heating element. The company is pretty good about warrantying the units. They go by the number on the plug to tell if the unit is still in warranty. Give them a call. 877-777-8042
Jan 19, 2014 | FoodSaver V2222 Vacuum Food Sealer
Foodsaver V845 is not sealing? vacuums okay, but won't seal bag.
WWW.FOODSAVER.COM
Jan 24, 2011 | Tilia Foodsaver V835 Vacuum Sealer
Not sealing
I have the same problem on my V2490. Will not heat to seal or create bags. So I took it apart! The heating element is only heating at the ends. Since Tilia doesn't repair or sell parts, I found a cite that carries replacement items.
www.elementandteflon.com/product/HE-14-FS
I don't know how if a replacement element will help. I am trying to find a wiring diagram to make sure i do it right...
Sep 19, 2010 | Tilia FoodSaver VAC420
Dolphin Dive Center
May 17, 2010 | Tilia FoodSaver V2240
My food saverf V 835 just stopped sealing. I haven't used it that much, and it worked fine last time I used it.
I just spoke to customer service. I was told there is no replacement part for the heating element. They did offer me a discount on a new Foodsaver.
Feb 21, 2010 | Tilia Foodsaver V835 Vacuum Sealer
I need a new heating element for Foodsaver V2060.
Jan 24, 2010 | Tilia FoodSaver V2240
My Tilia Foodsaver 370 won't turn on. A light
you have to press hard to make it close than it should work
Aug 22, 2009 | Tilia Foodsaver V835 Vacuum Sealer
Foodsaver vac1050 wont stop runing go to 3 bars thats it
Dolphin Dive Center
Aug 12, 2009 | Tilia Foodsaver V835 Vacuum Sealer
Kitchen Appliances - Others Logo
1,498 people viewed this question
Top FoodSaver Kitchen Appliances - Others Experts
Marvin
Marvin
Andrew Taylor
Andrew Taylor
Jim Busse
Jim Busse
Level 1 Expert
Are you a FoodSaver Kitchen Appliances - Other Expert? Answer questions, earn points and help others
