SOURCE: HP 5610 Will not print Color documents, only Black and White
Chances are that your print driver is set to print in black and white
while the copier side is automatically detecting that your original is
in color. To have the printer print in color: Select file print, select your printer and hit preferences. Select the Paper/Quality tab and switch from Black and White to Color.
Henry
SOURCE: Can't Print with black ink because all color ink are empty.
Hi
In case you have removed the empty colour cartridge from the printer put it back it will allow you to print. If the empty cartridge is still there and its not allowing you to print in black ink then you need a new colour cartridge .
Please contact for any further clarification.
Thanks
Rylee
SOURCE: hp psc 750 won't print with new color ink cartridge
To solve the
printing problem..
# Hold the cartridge upside down, with the
bar-code label facing you and take a damp paper towel.
# Use the towel to wipe the printhead of the
cartridge on the bottom (where the ink comes out). Wipe the printhead
horizontally in one direction only (left to right).
# Continue doing this until it looks clean.
# Then dab the cartridge on the towel to make sure
the ink is flowing.
# Next, look inside the printer and locate the
carrier that holds ink cartridges. Caution: Make sure the cartridges are not
installed at this point.
1. Look for a shiny piece of metal underneath the
contacts at the back of the carrier.
2. Take a damp cotton swab (use water only!) and
wipe along the bottom of the shiny metal piece. Note: You may need more than
one swab.
# Reinstall the cartridges, making sure you snap
them correctly into the printer.
Hope this help. Please
Rate My Response! Thanks!
SOURCE: HP K5400 will not print black
Check the black/yellow print head.If necessary replace it.It's part number is C9381A, #88
SOURCE: How to set hp deskjet 3550 inkjet printer to print
To Save the color ink you can change the printer settings to Black Only.
To Setup:
That's it...
Hope this will be helpful to you..
Thanks & regards
Nandu :)
