Unit not dispensing water when handle is pressed. I cleaned the jets, rollers and vacuum. Looked at solenoid, appears to be working. Water not moving from tank. Cleaned tank port also. Jets were clogged with calcium, rollers full of debris, and vacuum is working fine. Any ideas?
Did you clean the filter on the water tank. It's generally a red screen type device. Additionally, there is a filter under the Flow Indicator, unscrew the cap, lift out the propeller, lift the filter screen and clean it. Reassemble in reverse order. If you occassionally run one and half cups of white vinager through the machine it will clean out the calc buildup. Additionally, the filters should be cleaned after each use.
