20 Most Recent
Bissell Brushroll Proheat 2X 8920 9200 9400 Questions & Answers
How do I get Bissell Proheat 2X to work. Not dispensing water.
Did you clean the filter on the water tank. It's generally a red screen type device. Additionally, there is a filter under the Flow Indicator, unscrew the cap, lift out the propeller, lift the filter screen and clean it. Reassemble in reverse order. If you occassionally run one and half cups of white vinager through the machine it will clean out the calc buildup. Additionally, the filters should be cleaned after each use.
7/30/2016 7:59:20 PM •
Bissell...
Answered
on Jul 30, 2016
What is the best way to unclog the tubing from the shampoo container to the water supply. My machine, I thought, was working well! Then I realized I did not see movement in tank of shampoo and the car
the machine has to run for few minutes in the parked postion to heat the water or it will not dispense, for one for twoif you turn the heat off and add hot water to the tank instead it will bypass the heating and work in the meantime best way to unclog after following these steps is there is an airlock in tline turn heat off in parked position and motor on hold the trigger down for about 15 to 20 seconds release and turn off, then in parked position (locked) upright pull trigger and hold then turn on power you then will have ceased the airlock if you want to clean the unit after trying this baking soda and apple cider vinegar is best, drop the handle to ground pull the tank out and loof for the round area that the tank plug goes into take a push pin and poke the holes, then dump the baking soda and vinegar that is mixed from a cup by a few drops to sizzle in there, lift and lock and turn on holding the trigger and there ya go, have fun
1/2/2015 10:12:42 PM •
Bissell...
Answered
on Jan 02, 2015
Cant find heater in bissell 8920
I have one and watched a video on youtube that shows the red washer in the improper place under water tank. It shoed in unit base. He removed with screwdriver and placed back on nipple on the water tank and it worked.
1/2/2015 3:41:06 PM •
Bissell...
Answered
on Jan 02, 2015
Bissell spun scrub won't dispense water. Unplugged and plugged back in, press x valve, etc etc model 20391
Here are some troubleshooting steps you can try:
Check the clean water tank: Ensure that the clean water tank is not empty and is filled with warm tap water and the appropriate Bissell solution. The cap of the clean water tank should be properly closed.
Re-seat the water tank: Remove the clean water tank from the machine and then re-seat it back into the machine.
Check for clogs: There could be clogs in the system that are preventing the water from dispensing.
Check the pump motor: If the above steps don't work, there could be a more technical problem like a malfunctioning pump motor.
If these steps do not resolve the issue, it may be best to contact Bissell customer service or a professional for further assistance.
Bissell Carpet Cleaner Not Dispensing Water [SOLVED] (vacuupedia.net)
My Bissell little green machine has no suction at the hose end.
If your Bissell Little Green Machine has no suction at the hose end but good suction underneath the dirty water tank, try these steps: check for clogs in the hose and attachment, ensure the tank and filters are properly seated, test without an attachment, inspect for damaged hoses or seals, clean the machine, and run hot water through the hose. If the issue persists, contact Bissell customer support for assistance or consult your user manual for specific troubleshooting steps.
