Car Audio & Video Logo
Posted on Nov 03, 2015
Jenson jdvd 7700 power harness pin location - Jensen Car Audio & Video
2001 GMC Yukon stereo wiring colors
PART COLOR LOCATION 12 VOLT CONSTANT RED (+) @ IGNITION SWITCH HARNESS STARTER YELLOW (+) @ IGNITION SWITCH HARNESS STARTER 2 N/A IGNITION 1 PINK (+) @ IGNITION SWITCH HARNESS IGNITION 2 WHITE (+), See NOTE #6 @ IGNITION SWITCH HARNESS IGNITION 3 N/A ACCESSORY/HEATER BLOWER 1 ORANGE (+) @ IGNITION SWITCH HARNESS ACCESSORY/HEATER BLOWER 2 N/A KEYSENSE LIGHT GREEN (-) @ IGNITION SWITCH HARNESS PARKING LIGHTS ( - ) WHITE (-) @ BCM, LIGHT BLUE plug, Pin A5, See NOTE #4 PARKING LIGHTS ( + ) BROWN (+) @ BCM, LIGHT BLUE Plug, Pin B6, See NOTE #4 POWER LOCK LIGHT BLUE (TYPE A) @ BCM, BROWN plug, Pin A4, See NOTE #4 POWER UNLOCK WHITE (TYPE A) @ BCM, BROWN Plug, Pin A3, See NOTE #4 DOOR TRIGGER See NOTE #2 @ BCM, See NOTE #4 DOMELIGHT SUPERVISION TAN (-) @ BCM, PURPLE Plug, Pin B4, See NOTE #4 TRUNK RELEASE N/A SLIDING POWER DOOR N/A HORN BLACK (-) @ STEERING COLUMN HARNESS TACH WHITE (AC) @ ECM, See NOTE *2 WAIT TO START LIGHT DARK BLUE (-), See NOTE #5 @ INSTRUMENT CLUSTER BRAKE WHITE (+) @ SWITCH ABOVE BRAKE PEDAL FACTORY ALARM DISARM LIGHT GREEN (-) @ BCM, PURPLE plug, Pin B3, See NOTE #4 ANTI-THEFT YELLOW (+), ORANGE/BLACK (-) and RED/WHITE (Not used) GM's PASSLOCK 2 System, these wires exit the Ignition Switch Tumbler together and are in the Main Ignition Switch Harness in the Column. EXTRA INFORMATION NOTE #1: This vehicle is equipped with the PASSLOCK 2 ANTI-THEFT SYSTEM and will require a 791 Bypass Module for Remote Starting, to order go to the SECURITY BYPASS MODULE Page on this website. NOTE #2: This vehicle has 2 door trigger wires, the DRIVERS DOOR is a TAN (-) PURPLE plug, B4 and ALL OTHER doors BLUE/WHITE (-) LIGHT BLUE plug, Pin B11 at the BCM use both Door Trigger wires and DIODE ISOLATE when connecting to an ALARM SYSTEM, to connect, See DIAGRAM. NOTE #3; The ECM (Engine Control Module) is located near the battery, down low, between the fender and the fan, under a BLACK plastic cover. On the 4.3L engine it is in a 20 pin connector labled RED. On the 4.8L, 5.3L and 6.0L engines it is located at Pin 10 in the RED connector NOTE #4: The BCM (Body Control Module) is located behind the drivers side of dash, with the plugs facing the rear of the vehicle. NOTE #5: when hooking up a remote starter, if you cannot get the (+) or (-) Wait to Start wire on the Remote Starter to work properly, you will then need to disconnect this wire and Program the Remote Starter for the 5, 10, 15 or 20 Second Wait to Start Timmer in the Installation manual. NOTE #6: IMPORTANT !!!!! this wire MUST BE CONNECTED as IGNITION #2 for REMOTE STARTING!!!!!!
1helpful
I have a Jensen car stereo m 9213 with no wire harness power /speaker plug for the back of the unit, I need to know witch pin is the Power pin, and all the pin destination are,
Find the harness. Your best bet. Hit the wrong wire with power(those pins are really close together) and you will no longer have a Jenson stereo.
My jensen jdvd-7700 keeps on loading nothing happens
contact jensen sounds like a faulty dvd player if still under warranty they should fix it for free
3helpful
Jensen DVD player (JDVD 4301) does not show picture when DvD is inserted. Message on screen "Warning Stop Watch Video" display on blue screen although I can hear the movie playing. Did I connect...
Jenson requires the green wire to be connected to the vehicle parking brake.(Safety feature) this green wire requires a negative switch to activate the screen.
2helpful
2answers
I need a radio wiring digram color code for 2009 chevy silverado
2009 CHEVROLET SILVERADO C1500 4DR TRUCK WITH 4.3L ENGINE AND STANDARD AUDIO SYSTEM
Remote Start
WIRE COLOR POLARITY LOCATION
Battery RED/WHITE (+) IGNITION SWITCH HARNESS
LOW CURRENT, FOR HIGH CURRENT USE RED/BLACK AT VEHICLE FUSE BOX
Ignition 1 PINK (+) IGNITION SWITCH HARNESS
Accessory 1 BROWN (+) IGNITION SWITCH HARNESS
MAY BE YELLOW ON SOME MODELS
Accessory 2 PINK/BLACK (+) IGNTION SWITCH HARNESS
FOR REMOTE START INTEGRATION
Starter 1 YELLOW/BLACK (+) AT MODULE UNDER HOOD BEHIND DRIVER HEADLIGHT
NOT FOR REMOTE START, FOR REMOTE START INFORMATION
Starter 2 PINK/BLACK (+) IGNITION SWITCH HARNESS
Anti-Theft Type GM PASSKEY III® ANTI-THEFT SYSTEM
Anti-Theft Descript THE KEY SENDS AN RF SIGNAL TO THE BCM MODULE THROUGH AN ANTENNA LOCATED AROUND THE IGNITION CYLINDER
Key Sense PINK (+) IGNITION SWITCH HARNESS
Tachometer WHITE (-) AT IGNITION COIL
Speed Sense YELLOW/BLACK (AC) AT ECM MODULE UNDER HOOD ON DRIVER FENDER
BLACK PLUG PIN #57
Parking Lights LIGHT BLUE (-) AT VEHICLE LIGHT SWITCH
Brake Lights LIGHT BLUE/WHITE (+) AT SWITCH ABOVE BRAKE PEDAL
IGNITION MUST BE ON FOR THIS WIRE TO TEST
Reverse Lights DARK BLUE (+) AT BCM MODULE UNDER DRIVER DASH
Horn TAN (-) IN HARNESS AT STEERING COLUMN
ALSO AT BCM MODULE UNDER DRIVER DASH
Modules
WIRE LOCATION
Please select another category
Doorlocks/Windows
Power Unlock WHITE (-) AT BCM MODULE UNDER DRIVERS SIDE OF DASH
THIS WIRE UNLOCKS THE REAR DOORS ONLY, WILL REQUIRE A 5-WIRE SET-UP IN EACH FRONT DOOR TO INTEGRATE OR A SERIAL DATA MODULE FROM AN ALARM MANUFACTURER
PowerLock LIGHT BLUE (+) AT BCM MODULE UNDER DRIVERS SIDE OF DASH
THIS WIRE LOCKS THE REAR DOORS ONLY, WILL REQUIRE A 5-WIRE SET-UP IN EACH FRONT DOOR TO INTEGRATE OR A SERIAL DATA MODULE FROM AN ALARM MANUFACTURER
i would use a DLPK module
DLPK (2009 Chevrolet Silverado)
W2W
CC-Heated Seats Activation
DL-Arm Factory Security
DL-Disarm Factory Security
DL-Door Lock Control
DL-Door Unlock
DL-Driver Priority Unlock
PK-Immobilizer Bypass-Data No Key Req'd
RS-RAP Shut Down (Remote ACC Power)
RS-Tach / RPM Output
SS-Entry Monitoring ALL Door Pins
SS-Entry Monitoring Driver Door Pin
SS-Entry Monitoring Front Door Pins
SS-Entry Monitoring Hood Pin
D2D
CC-Heated Seats
DL-Door Unlock
Hope helps.
4helpful
2answers
What color is the power wire in 1994 toyota pick up
this might help
1994 Toyota Pickup Car Security Wiring Diagram
Battery Constant 12v+ Positive Wire (+): White And White/Red
Battery Constant 12v+ Positive Wire Location: Ignition Switch Harness
Starter Positive Wire (+): Black
Starter Positive Wire Location: Ignition Switch Harness
Ignition Positive Wire (+): Black/Yellow
Ignition Positive Wire Location: Ignition Switch Harness
Second Ignition Positive Wire (+): Black/Yellow Or Black/Red
Second Ignition Positive Wire Location: Ignition Switch Harness
Accessory Positive Wire (+): Blue/Red
Accessory Positive Wire Location: Ignition Switch Harness
Parking Light Negative Wire (-): Red/Black
Parking Light Negative Wire Location: At Steering Column Harness
Parking Light Positive Wire (+): Green
Parking Light Positive Wire Location: In Drivers Kick Panel
Power Door Lock Negative Wire (-): Blue/White
Power Door Lock Negative Wire Location: At Door Control Relay. The door control relay, is located behind the driver dash speaker.
Power Door Unlock Negative Wire (-): Blue/Yellow
Power Door Unlock Negative Wire Location: At Door Control Relay. The door control relay, is located behind the driver dash speaker.
Door Trigger Negative Wire (-): Black/White Or Black
Door Trigger Negative Wire Location: At 2-Pin Plug, Top Of Fusebox
Domelight Supervision Wire: Use Door Trigger, Requires Relay
Domelight Supervision Wire Location: N/A
Horn Negative Wire (-): Green/Red
Horn Negative Wire Location: At Steering Column Harness
Tachometer Wire Negative Wire (-): Black
Tachometer Wire Negative Wire Location: At Diagnostic Connector. The diagnostic connector, is located on the passenger inner fender near the fuse/relay box.
Brake Light Positive Wire (+): Green/White
Brake Light Positive Wire Location: At Switch Above Brake Pedal
Factory Alarm Disarm Wire (-): N/A
Factory Alarm Disarm Wire Location: N/A
Factory Anti-Theft System: N/A
Factory Anti-Theft System Location: N/A
1helpful
HORN DIAGRAM FOR A DODGE RAM 1500 (CONNECTIONS)
Battery Constant 12v+ Positive Wire (+): Black/Orange And Red/White
Starter Positive Wire (+): Yellow
Ignition Positive Wire (+): Blue (16 Gauge)
Second Ignition Positive Wire (+): Yellow/Red
Accessory Positive Wire (+): Blue (10 Gauge)
Second Accessory Positive Wire (+): Orange
Second Accessory Positive Wire Location: Ignition Switch Harness
Parking Light Positive Wire (+): Black/Yellow
Parking Light Positive Wire Location: At Headlight Switch
Power Door Lock Positive Wire (+): Orange/Violet
Power Door Lock Positive Wire Location: In Drivers Kick Panel, White 6-Pin
Power Door Unlock Positive Wire (+): Pink/Violet
Power Door Unlock Positive Wire Location: In Drivers Kick Panel, White 12-Pin
Door Trigger Negative Wire (-): Yellow
Door Trigger Negative Wire Location: At Headlight Switch
Domelight Supervision Wire: Use Door Trigger (Requires Relay)
Horn Negative Wire (-): Black/Red
Tachometer Wire Negative Wire (-): Gray
Tachometer Wire Negative Wire Location: At PCM, Connector 1, Pin A7. The PCM (powertrain control module) is located on the firewall next to the wiper motor.
Brake Light Positive Wire (+): White/Tan
Factory Alarm Disarm Wire (-): Black/Orange (To disarm requires a (-) negative through a 1565 ohm resistor and an extra relay to connect.)
Factory Alarm Disarm Wire Location: In Drivers Kick Panel, White 12 Pin Plug
Top Jensen Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
