If you remove the lower front panel, you just might be able to see the pump.
I surely hope so.
If you can, try to determine whether the pump is leaking or one of the hoses or the pipe fitting ( maybe brass).
If the metal fitting is leaking, you may need teflon tape to rethread it.
If a hose is leaking, a new clamp may help, unless it is cracked.
I guess you know most built-ins can be removed about 6 - 8 inches out into the kitchen for service and inspection. The hoses and wiring should be long enough to allow this.
Usually the built-ins are secured only to the counter top with a couple of screws in the front.
If you need a new pump, you can go online and get one from "Sears Parts Direct".
God bless your efforts.
