The drain pump pumps water out the drain hose. If the drain pump is cracked or damaged, or if the bearings are worn out, the drain pump may leak water. ... The tub seal might be torn, causing water to leak from the seal. If the tub seal is leaking water, water may leak through the tub seal and into the tub bearings.
SOURCE: accessing burner and installing LP conversion on Maytag Bravo
you need to obtain a jet (orifice) of the correct size for the gas you wish to use. remove the burner and, replace the existing jet; that is all there is to it.
SOURCE: maytag bravos dryer belt needs to be replaced
Check in the back and see if the belt has a wide span on it. If it does, it doesn't only go around the fan pulley but also the drum (Which is usually the case). THis being the case you need to look for and screws you can find on the dryer outer casing because you will need to remove the outer casing to get to the drum. If you look for screw on the upper part just inside the door many times the upper deck is on hinges and will tilt backward so you can view the top of the drum with the belt on it. Remember how it came apart; it goes back together in reverse manner. Once you usually find the belt tension pulley through the back of the dryer compartment, let the tension off the pulley and slide the belt off of it. Once you get the belt off put it back on just like the old one.
SOURCE: maytag bravo mvwb750wq 28"
Have you tested the lid switch, if it is not making the washer will not spin. try using a pen or small bladed screwdriver to depress on the switch to see if you hear it clicking, although sometimes it wont work even if it clicks when they go bad. The washer should work as normal till it gets to the spin cycle, then without the lid switch working it won't go any furthur. You can try jumping across the leads to see if this gets it to spin and this will tell you if the switch is bad or not.
SOURCE: Maytag Bravo showing F on
heres all the fault codes for your machine, and items to check for them http://www.assuredparts.com/MaytagBravosDryerFaultCodes.html
SOURCE: Any problems with Maytag Bravos mvwB750w?
Remember its whats inside that maters - I will never ever again buy another Maytag! Bearings are a disaster in the top loaders.
Iām happy to help further over the phone at https://www.6ya.com/expert/charles_6bf94c079488b145
