These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience. If blinks continue without any pause, the main board is faulty
Hello lets start in your power distribution center under the hood engine compartment behind your battery it is a black box with your head light relay the diagram is detailed ounce located remove and replace this should restore your head lights from blinking.
try to turn off the printer, remove the power cord, then press the power button for about 5 secs. plug it back, turn it on. If same thing, press the cancel button for about 10 secs. if still the same, try to check the cartridges, remove them and make sure they are not yet empty, shake them a few times, then connect them back. Make sure no paper jam as well.
1x- lamp cover (close lamp cover)
2x- temperature problem (too hot. clean out and cool down)
3x- power problem (check power)
4x- fan problem (one or more fans not running)
6x- lamp fails to light (lamp or ballast problem)
