Kenwood VR-357 Logo
A
Anonymous Posted on Jun 30, 2015
My kenwood 357, when i try to put the volume up it stop on 10 and then the vol don`t go more up de .
1 Related Answer
smarthome2
Frank Fulton
  • 1114 Answers
  • Posted on Dec 23, 2009
SOURCE: I have a Kenwood VR-407. TV and Blue-ray are
Check the manual for "Volume offset" at the input mode. I'll pull the pdf on the unit, If I find it, I will send the instructions. Hope this helps
So i went to use my luxor smart tv today after a few months and the volume wont stay up it lets me turn it up but then goes straight back down to 0 why is this and how can i stop it ?
Hello Skye, you can have two problems, one, that in the remote control, the Vol - button is locked, or that you have on the TV, the same button Vol-, also locked, try to take the remote control of the room where is the TV, so that it can not affect the operation of the TV, you must try to increase the volume from the TV and check if the problem is solved, if it continues, we are facing a problem of TV functions, look in the menu , reestablish factory setting and if it continues, I suggest you take it to a specialized technical service
I hope you can solve the problem
Greetings Franco Dosil
Hola Skye, puedes tener dos problemas, uno, que en el control remoto, se encuentre trabado el bot?n de Vol -, o que tengas en el televisor, el mismo bot?n Vol-, tambi?n trabado, prueba sacar el control remoto de la habitaci?n donde esta el televisor, a los efectos de que no pueda afectar el funcionamiento del TV, debes probar subir el volumen desde el TV y verificar si se soluciona el problema, si continua, estamos frente a un problema de funciones propias del televisor, busca en el men?, restablecer a ajuste de fabrica y si aun continua, te sugiero lo lleves a un servicio t?cnico especializado
Espero puedas resolver el problema
Saludos Franco Dosil
How manage the volume for kenwood tuner kt 45
Hello Educare Shalom, to be able to handle the volume of your kenwood tuner kt 45, you should connect a stereo potentiometer of 50 kOhms Linear in the output signal or connect it to a sound mixer, to be able to regulate the output level
Hola Educare Shalom, para poder manejar el volumen de tu kenwood tuner kt 45, deber?as conectar un potenciometro est?reo de 50 kOhms Lineal en la se?al de salida o conectarlo a un mezclador de sonido, para poder regular el nivel de salida
3answers
Will not charge
My grandson forgot his password for his Nextbook Tablet, how can I unlock the screen to rest his password.
I have a 2001 chrysler voyager installed a kenwood stereo and when i raise the volume to where its lound the radio will turn off and on untill i lower the vol
My electronics savvy source says you may be overdriving the amplifier in your Kenwood stereo to an impedance-mismatched set of speakers, meaning that the speakers are impedance mis-matched to the Kenwood stereo, and therefore operate ok (but inefficiently) at low volume, but cut off completely at higher volume.
Fix: match the impedance of your speaker network to the specs on your Kenwood car stereo. Once this is done, you should be able to crank up the volume to the point of permanent hearing loss.
SAFETY CAUTION - sound levels above 85 decibels produce NIHL (noise-induced hearing loss).
http://www.dangerousdecibels.org/education/information-center/faq/
I am simply trying to hook up the stock sub that came with this product vr 357. I don't see an input on the tuner do I need an amp of some sort or am I missing something
I think you're missing the manual(s).
http://www.retrevo.com/support/Kenwood-VR-357-Receivers-manual/id/480dj197/t/2/
describes how to use a >> powered << subwoofer with the VR-357.
Speakers are OUTPUT devices. As far as the manual goes there is no STOCK subwoofer with this receiver. What's yours and does it have a manual which might answer your question?
NO SOUND OUT OF RECIEVER, TURN VOLUME TO MAX AND CAN HARDLY HEAR ANYTHING
TURN THE VOUME CONTROL DOWN TO SOMETHING REASONABLE. MAX VOLUME IS ONLY USED TO DESTROY SPEAKERS.
Unmute it, de-select Tape Monitor, de-select M.Input.
http://www.retrevo.com/support/Kenwood-1060VR-Receivers-manual/id/478ci953/t/2/
1helpful
DNX7120 issue with VOL increase button. When this button is pressed once, the volume skyrockets to max, VOL decrease button does not work right away to lower the volume, nor does the ATT button. Unit...
I had the same issue. You can use the on screen volume buttons on screen to stop issue and don't use the physical buttons anymore. Watch out about a month after the volume problem started all physical buttons on my DXN7120 stopped working. There are a few reports of this online, I have not found a fix yet.
2answers
My Kenwood DPX-4020 suddenly turns up to max vol
you probably have a bad switch. you need to use a multimeter and check the resistance of your volume up switch, if less than a few meg., the switch is bad.
Remote code
1. programed RCVR with code 0314
2. then assigned a key (such as the TV/VCR key) with the EFC number of 300
3. then reprogramed RCVR w/ code 0027
498 "surround mode"
568 "+10"
578 "band"
370 "stereo"
702 "6"
444 "4"
447 "2"
317 "8"
701 "0" (zero)
450 "7"
704 "5"
707 "3"
449 "1"
577 "9"
384 "tape 2"
252 "mute"
255 "vol down"
512 "power"
515 "vol up"
572 "channel down"
257 "channel up"
Try This an see if works
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Ngoro
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
