I have a red halo around all figures in tv,,,,,what to do
Without knowing the model number, i can only give you some ideas on what to check.
If the tv was working fine, and started experiencing the problem after being moved, check your focus. you may or may not have an electronic focus pot on the rear of the tv, and you should have a manual focus located on the lens assembly, loosen the wingnut and rotate the lens to focus it.
also check the crt coolant level, if it has a bubble in it, it may be causing the red halo effect.
if the red is to the top or side of the characters and not completely surrounding them, it may be a convergence issue, check the manual for convergence procedures, if it does not have them, your best bet would be to take it to a service tech.
