20 Most Recent Hitachi 50FX30B 50" Rear Projection Television Questions & Answers
If hitting the TV sometimes corrects the problem then usually there are some bad solder connections. As the sets heat up and cool down the pc boards slightly expand and contract, where a component leg sticks through the board and is soldered on the other side a small crack will develop around the solder connection. Sometimes they are easy to see, sometimes very difficult. One way to narrow down where the bad connection is, being very careful because of dangerous voltages, using something non conductive lightly tap different parts of the pc boards to see what area is most sensitive, then you would need to unplug the set and get to the bottom of that board and look for the bad connections.
Hitachi 50FX30B... | Answered on Mar 04, 2012
You can most likely connect your computer to your TV, but it depends on what kind of connections your computer has and what inputs your TV has. The best solution would be if your computer has an HDMI port and your TV also has one. If your computer doesn't have one but it has a DVI connecter, that is the second best solution because you can just get a DVI to HDMI adaptor. The last solution is the worst case scenario because it is analog. If your computer and TV both have VGA (the blue trapezoid plug) you can just get a VGA cable and connect the two like that. The reason that is the worst is because the quality is not that good, but in the end it will work. If you want sound, you will need a cable unless you have an HDMI port on your computer and TV. If you don't just go to the store and get a 3.5 mm headphone jack to RCA connectors and plug that into your TV.
Hitachi 50FX30B... | Answered on Jul 28, 2011
you ahve a dirty fan restricting air flow.
Hitachi 50FX30B... | Answered on Feb 26, 2011
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded over.
You can find more details and solutions here on Fixya at the following link below. Or click HERE
3d884ac.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dul
Hitachi 50FX30B... | Answered on Dec 04, 2010
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Hitachi 50FX30B... | Answered on May 30, 2010
Try encompass parts online.
Hitachi 50FX30B... | Answered on Apr 14, 2010
http://www.wikihow.com/Repair-a-Scratched-or-Finger-Printed-Monitor-Screen
www.wikihow.com/Discussion:Fix-a-Scratch-on-an-LCD-Screen -
www.pcextreme.net/style/fix-a-scratch-on-the-lcd-screen/
Check out those links they will help you.
Hitachi 50FX30B... | Answered on Mar 22, 2010
Convergence ic's need replaced. The average shop charges about $250.00.
Hitachi 50FX30B... | Answered on Dec 06, 2009
try waving and speaker magnet near the affected area and draw it away from the tv this somtimes puts the picsells back to normal by pushing the fosfer dots to the back of the screen
Hitachi 50FX30B... | Answered on Oct 07, 2009
Its possiable that you may have poor solder connections where our STK ICs are resolder them and transistors they are big black ICs will have STK392-110 on them. I would First start out with soldering everything on convergence Board.
Hitachi 50FX30B... | Answered on Sep 24, 2009
sounds to me like you either have a blown fuse, or a power supply problem. I would take it to a reputable service center that won't rip you off, and see if they can repair it for a reasonable price.
Good Luck!
Hitachi 50FX30B... | Answered on Jun 11, 2009
hi, this message means that the tv is not getting a signal, what signal are you giving it ? cable, satellite, antenna ??? when you first turn on the tv it should say on the screen ch or v1 etc,. you could have a bad tuner or the set is not tuned to the proper input on the back of the tv, let me know what your input signal is & where on the back you have it connected, video-tek
Hitachi 50FX30B... | Answered on Jun 05, 2009
Hi, you`ve lost your convergence IC`s, At our shop here in western florida this runs right around $246.00, price will depend on your geographical location and who you call. gl, video-tek
Hitachi 50FX30B... | Answered on May 31, 2009
needs a convergence board repair, not too hard to fix if you are handy with a soldering iron.
get the 2 convergence chips for this model @ partsstore.com
Hitachi 50FX30B... | Answered on Apr 21, 2009
Turn your TV on.
Press and hold the TV mode button until all the other mode buttons light up.
Press the blank POWER button. (If your remote only has one POWER button, press that one)
Press the UP ARROW button repeatedly until your TV turns off.
Press the POUND (#) button to confirm.
Cheers
Hitachi 50FX30B... | Answered on Apr 01, 2009
That means that you need to replace the color wheel.
Hitachi 50FX30B... | Answered on Mar 21, 2009
STKs you have 2 of them big black ICs STK392-110s use 180s to get parts call electronix parts 1-800-223-3205,if you need anymore help let me know.
Hitachi 50FX30B... | Answered on Dec 16, 2008
Televison & Video Logo
29 questions posted
Top Hitachi Televison & Video Experts
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Hitachi Televison & Video
Most Popular Question
shadows double vision
  • Televison & Video
