20 Most Recent
Hitachi 50UX52B/53K 50" Rear Projection Television Questions & Answers
When I plug in the
The problem you have mentioned is caused due to loss of high-voltage. We have to perform a component level diagnosis to get to the source of the problem. Which begs the question how good are your electronics soldering skills? Do o you have a multimeter handy? Can you follow the schematics in a service manual(with my help ofcourse)
1/17/2011 5:55:14 PM •
Hitachi...
Answered
on Jan 17, 2011
Double images or halos
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded overs.
You can find more details and solutions here on Fixya at the following link below. Or click HERE
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
10/15/2010 3:39:43 AM •
Hitachi...
Answered
on Oct 15, 2010
Hitachi 50UX53K Ultravision will not stay on
The set is going into shut down mode for avariety of reasons. Some of the more common problems are vertical o/p ic bad connection or failure, poor solder connection usually in the power or hv section or possibly comb filter circuit breakdown causing 12V line to short. This set incorporate 7 or more shut down circuits and any one of them could be triggering - more trouble shooting is required
8/15/2010 7:03:48 PM •
Hitachi...
Answered
on Aug 15, 2010
We have blue ghosts with brilliant colors
This sounds like the most common thing that fails on projection TV's, regardless of the brand. The
convergence circuit has two STK392-110 IC chips mounted on
heat sinks to drive the convergence yokes. They typically last anywhere from 5-10 years, then they fail. A more robust part is now available (STK392-150) as a direct drop-in replacement. My shop has installed these IC's in hundreds of projection sets and had fewer than 1% of them come back with repeat failures. Also check the following low-ohm feedback resistors to make sure they did not go out of tolerance:
RK42: 2.7
RK46: 2.2
RK58: 3.9
RK52: 3.3
RK50: 3.3
RK54: 2.2
8/18/2009 8:43:06 PM •
Hitachi...
Answered
on Aug 18, 2009
TV turns on but produces no visual or audio. Screen just stays black
Your lamp is burned out . I have a 52" hitachi lcd as well, and i have hadd to replace the lamp once a year. its a mercury based bulb which emulates alot of heat and if your exhaust fans are not working properly it will cuase it to fail or burn out more frequently than it should. cost is @ $120.00 for replacement bulb
4/12/2009 4:51:26 PM •
Hitachi...
Answered
on Apr 12, 2009
Lost power
The symptom you have needs to be looked at by a qualified technician for proper diagnosis. There are 9 LED`s ( 8 green, 1 red) in the power supply that light up under normal condition. These LED`s are used to help pinpoint the area of trouble. For example, when power is applied all LED`s but one lights up. The unlit LED may indicate the +27 volt source is bad. That will alert the technician to check components related to the +27v line. Since there are 8 green LED`s and 1 red, each having multiple suspects leads us to Mr Spock`s comment to captian Kirk." there are endless possibilities"
1/10/2008 2:21:52 AM •
Hitachi...
Answered
on Jan 10, 2008
