20 Most Recent Hitachi 50DX20B 50" Rear Projection Television Questions & Answers
Lens are adjustable but if picture is 3d or colors like the photos it is not an adjustment.
Hitachi 50DX20B... | Answered on Oct 26, 2012
For the Hitachi model indicated here it is not possible and if worked would have some real issues anyway--this set was not designed for this type of connection.
Hitachi 50DX20B... | Answered on Apr 30, 2012
GOOD question and well asked----Start at the beginning.
if light on main fuse is good---do you hear the power relay click on and off?
These sets for trouble shooting use a number of green and one red LED inside on the board--the red one should be on when power is connected and the others at turn on all should light--if do this with back off look for the Green ones---when set turned on do all light and then go out--look for one that goes out first or last---each is connected to a specific voltage coming out of the power supply---they will lead you to the area where the trouble is---this set is old enough you may be able to find a service manual online.
I have fixed a lot--going to need a volt/ohm meter for any real tests.
I am ready to help if you need it.
Hitachi 50DX20B... | Answered on Apr 23, 2012
Replace or resolder your convergance IC's. What is a common problem is over time the heat emitted by the chips weakens the solder joints on the circuit board. If your lucky just a resolder job is all it needs.
Hitachi 50DX20B... | Answered on Sep 04, 2011
Remove the rear panels.
Hitachi 50DX20B... | Answered on Jun 03, 2011
Please do us a favor and rate this solution after reading.
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both. Repair kits with instructions are also avail from www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Hitachi 50DX20B... | Answered on Apr 23, 2011
I believe you are referring to the convergence adjustment. If the cross-hairs do not align then its a 100% guarantee that the source of the problem are the convergence amplifier ICs. We will have to replace the two STK ICs along with any resistors found to be faulty which begs the question- Do you know how to solder?
Hitachi 50DX20B... | Answered on Apr 22, 2011
You have a convergent problem, where the red, blue, green projector lamps are out of synch. See: http://www.youtube.com/watch?v=esk4nYZKFcg for a pictorial on how to fix convergent.
Hitachi 50DX20B... | Answered on Dec 29, 2010
either the high voltage section has burned out some components or your lamps are defective....in any case...you need a service shop.....without equipment to analyze the problem...your shooting in the dark......that fault could really be anything....power supply, video board, sound board, horizontal section, vertical section, lamps.....etc....so it's best to bring it in....good luck
Hitachi 50DX20B... | Answered on Dec 04, 2010
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
  • Screen looks 3D
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
Hitachi 50DX20B... | Answered on Jun 06, 2010
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai2_bing.gif,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Hitachi 50DX20B... | Answered on Apr 22, 2010
Projection TV sets have several common problems listed below.
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - TV makes a chirping sound.
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Hitachi 50DX20B... | Answered on Mar 06, 2010
Try unplugging and plugging back up the power cord to reset it.
Hitachi 50DX20B... | Answered on Feb 02, 2010
Do not adjust any knobs as instucted in the previous thread if you TV have a convergence problem. Doing so will only make things worse. The blog does however show you how to fix other common problems with these sets.
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
Using your original remote go-to the tv settings then goto the convergence section.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Hitachi 50DX20B... | Answered on May 03, 2009
Hitachi 50DX20B 50" Rear Projection Television Logo
34 questions posted
Top Hitachi Televison & Video Experts
matt martin
matt martin
Todd Hill
Todd Hill
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Hitachi Televison & Video
Most Popular Question
hitachi model 50dx20b no sound or
  • Televison & Video
